Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000 paper feed jam
Whenever i go to print, the paper feeds in unevenly (right side first) and causes a jam. Hulk smash?
  • Anonymous Jul 23, 2008
    I'm having the same problem. I contacted canon and they said the rollers probably need cleaned.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Posted on Jul 23, 2008
When I print, the paper gets jammed. The paper is grabbed on one side and goes in unevenly thus causing the jam.
Hello!
We must feed curved paper to our printer. To avoid paper jam let the paper be straight and dry... thanks
Sep 07, 2011 | Canon PIXMA MX310 All-In-One Printer
It wont grab the paper to print
Paper feed problem:
Remove any loose paper in the printer.
Paper jams
85% of paper jams are caused by worn rollers .The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 03, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper goes in squint drags to one side and jams
In my experience the usual reason for this is something (obstruction) in the paper feed. Make sure you have a really good look right down inside the paper path as quite small objects will stop a correct feed. The fact that it is one side makes me thing something is in there. I have serviced printers before with coins, paperclips etc that have found a way in.
Nov 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 8500 won't feed paper
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Oct 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
CANON PIXMA IP1300 - The printer feeds in more than one page
I just had the same problem, I cleaned the rolers manually with alcohor and is working ok now
Oct 01, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feeds unevenly and won't feed properly
For me, although the paper was folding and jamming on the right, the problem was the farthest left roller. Just push a regular index card past this roller until it doesn't stick.  Good luck and thanks so much for this site.
Dec 29, 2007 | Canon Pixma MP500 All-In-One InkJet...
Dimantle my canon pixma ip3000
I had this problem yesterday with my iP3000, but it turned out to be my own fault. I had randomly pushed the control panel buttons, as I tend to do that with printers, while I was trying to quickly cancel a print job.
The symptoms:
roller wouldn't advance, a lot of noise like it was trying to advance, then two yellow light error flashes. I knew it wasn't out of paper.
By randomly pushing buttons, I clicked the Paper Feed Switch which toggled from top sheet feeder to cassette.
I downloaded the e-user's guide from Canon and learned what those control buttons are. I simply clicked the Paper Feed Switch and it toggled back to top sheet feeder. That fixed it for me.
Dec 07, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam on 1 side
at start paper jumps in gear pulls to one side
Sep 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
291 people viewed this question
old marine
old marine
Corne Viljoen
