Question about ASUS VW192S Monitor
More Auto Adjust
Thanks in advance for any help.
I run XP, and everything is fine unless I want to download a game. Then the "auto Adjust" appears on the black screen, and when I get a picture on there its far too large. I have clicked properties and changed by settings, but it has not helped. I am not computer savvy enough to know what to do.
Thanks,
Sandy
Na moiom monitore vw 192 s kartina desktop podvinulas na pravo. kak mne etu problemu reshit? iz meniu eto ne poluchilos.
Posted on Jan 14, 2010
All across the screen a lot of black colored dashes are appearing. everything is fine but these dashes doesn't look good
Try selecting Auto Adjust from the monitor's on screen display. Should be accessible from the buttons on the front of the monitor.
Also try downloading and using the latest drivers for the monitor.
Also try checking the monitor's technical specifications and making sure that the refresh rate on the computer is set to the optimal refresh rate per the monitor's manufacturer.
Jun 21, 2011 | Computers & Internet
I'm trying to change the screen resolution while running windows 7 because I have no desktop showing on my monitor
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try our free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below: 1) Restart your PC 2) Logon and wait for the black screen to appear 3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this) 4) Press the CTRL, ALT and DEL keys simultaneously 5) When prompted, Click Start Task Manager 6) In Task Manager Click on the Application Tab 7) Next Click New Task 8) Now enter the command: "C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX" Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it. 9) Click OK and your browser should start up and begin the download process 10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue. 11) Now restart your PC and the black screen problem will hopefully be gone.
Oct 11, 2010 | Computers & Internet
Scrapland and XP blue screen error - any solution?
it will be your memory(ram) problem .. check ur ram requirement of game...nd upgrade or replace the faulty ram
Aug 24, 2009 | Enlight Interactive Scrapland for Windows
Black screen
Find the program in the installation directory. It might be something like C:\Program Files\The Adventure Company\Microids\StillLife
Now right-click on Stilllife.exe, then click Properties. Click the Compatibility tab, then select Windows 98/ME from the drop down menu. Hit OK and try to run the game again. It should start up just fine.
Jul 18, 2009 | Microids Still Life for Windows
Screen sizing
Your problem is that the correct video driver is not installed and therefore cannot use all the video RAM.(the XP version of the video driver won't work with Win98).
When you adjust to True color at a higher resolution it drops to a lower resolution because it has insufficent video RAM, but you will get a higher screen resolution at a 16 bit color because it requires less memory (video RAM).
Install the Win98 driver for the graphics card and then it can use the full video RAM at a higher screen resolution with 32 bit color.
May 01, 2009 | Computers & Internet
Computer won't shut down
i read an forum, mboar asus shutten dwon NOT avaible.
Dec 29, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
Download problems
have you tried right clicking on the install icon and running it as administration?
With all new installed files that dont run as normal try running them as administration.
Hope this helps.
If not please post the exact error message that comes up when you click run.
Thanks
Dec 12, 2007 | Microsoft Windows Vista Ultimate Edition
ASUS VW192S Monitor Logo
179 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
