Question about Panasonic SC-HT670 System
Error DVD H07
When trying to play a disc it reads error H07 and then says disc no read. Panasonic dvd player main unit sc-ht67, I disconected the AC power supply cord, and then reconnect it, but it cant fix it.
Best Regards
Carmen
SOURCE: Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Posted on Dec 26, 2005
techman
  • 3130 Answers
SOURCE: Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Posted on Jun 19, 2006
  • 10 Answers
SOURCE: disk read error or it takes so much time, two days back disc was running smoothly but now when i insert d same disc, my player can't read it, a message appeared says disc is dirty...
take it to a authorised technician and tell him to either service it or just replace the lens circuit it will work again
Posted on Jun 20, 2006
zair
  • 82 Answers
SOURCE: dvd
Replace spindle motor.
Posted on Dec 09, 2007
marsrover
  • 682 Answers
SOURCE: tv Code!
http://service.us.panasonic.com/OPERMANPDF/SCHT67.PDF
Posted on Apr 04, 2008
@Hello - whenever I try to insert a disk to play it starts reading it (display reads READ...READ and then it stops and displays HO7 and won't play the disk at all. I've had the unit a few years but have...
H07 is a common error code for Panasonic DVD players. It means the traverse unit (spindle motor/laser assembly contained in one block) has failed. Usually it is the spindle motor part of this unit which fails first, (i.e. it doesn't spin the disc at all) causing the problem, but sometimes the laser can also fail as well. Because the motor and laser are contained in one device block, the whole part has to be changed, and this can only be done by an authorised service centre. The only trouble with that is the cost. Many DVD drives experience this (different brands giving different error codes) so it's not just confined to Panasonic.
There are only 2 ways to go here; either be prepared to spend a fortune in a workshop service to have the traverse block replaced/aligned (which would include a brand new laser), or simply buy a new player - which would give you a new remote AND an optional extended warranty if available; this would be considerably cheaper than repairing the old one.
Don't be put off from owning Panasonic - they are generally good products.
Feb 24, 2011 | Panasonic DVD-RV32 DVD Player
When trying to play a dvd , it shows H07
Traverse unit (spindle motor & laser assembly combined) is most likely faulty. The motor part usually fails first, which stops the discs from spinning, so the inbuilt laser cannot read them, hence the error code. This can be expensive to replace.
Jan 28, 2011 | Panasonic DVD-RV32 DVD Player
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Panasonic SC-HT670 System Logo
93 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
