I have a Samsung SyncMaster 971P and it flickers while starting up. If you turn it on and off a few times then it will come on with out flickering.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
The flicker might be caused by a defective plyback or a cold solder. Have it checked at the nearest service center.
Posted on Jun 20, 2008
The menu started flickering on and off and the color resolution depth has faded.
Ah, the Ol' menu flickers, and depth of color fading trick.
I remember back in '69 when.............
WHAT! !O_O!
Monitor is going bad. Believe it to be the monitor's internal power supply.
Suggest replace monitor.
Regards,
joecoolvette
Mar 18, 2013 | Samsung SyncMaster S20B350H - LED monitor...
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
It's simply gone blank... or into a coma perhaps.
But that is the only way -its replacement time Nothing for you to fix
Jun 18, 2007 | Samsung SyncMaster 971P LCD Monitor
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
