I have a 10GB Philips 1" external hard drive. The wire that goes to the usb connector is broken, making the data inacessible. I took it to Best Buy to see if they could repair it, and they said no, even though it seems like an easy soldering job. Is it really that hard to fix? Could I do it myself, or find someone who would do it?
It wasn't just the cable adapter--a wire broke inside the device, between the device and the usb interface. It's okay, though, my boss at work broke it open and re-soldered the wires (after the Geek Squad at Best Buy told me there was nothing they could do). It worked fine, and all the data was recovered!
Posted on Jun 20, 2008
    Novelist:
  • 119 Answers
If you can find or purchase another cable adapter just replace it. not worth fixing and might cause your external hard drive to crash if you get to fix the cable wrongly and will be spending more and losing both hard drive and cable
Posted on Jun 19, 2008
USB connector Hard Disk faulty
Usually you wont be able to change the USB-connector (problem 1: where to get an identical connector; problem 2: how to solder it without damaging something else). :-((
If you have important data on it, the best would be to take the hard drive out of the case and buy a USB-adapter for it (PATA or SATA as needed). With that you can access your data and copy them to something else - maybe a new external hard-drive.
Apr 10, 2014 | Buffalo Jeans Hd-Pnt500U3R 500Gb External...
Dropped SmartDisk
Depending upon how hard the jar was to the internal mechanism, the data may be salvageable. I would guess that the first problem is broken connections at the USB connector. This case is just snapped together with a laptop drive in it. Carefully open it up and look for anything broken.
Worse case scenerio, you can get an adapter to plug the drive into a standard IDE cable inside your tower system.
Dan
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
How broken is this WD external HD
It's not broken.
Try to use a usb cable with 2 connectors(plugs). I mean, you plug one connector(plugs) in the hard drive and 2 connectors in the computer. Because you have 5 volts per usb connector.
Or you can use a small nokia charger to start the hard drive.
If you need further assistance please post
Mar 16, 2010 | Computers & Internet
I have a 1TB iomega external drive but it only shows as 10GB. I have reformatted but it only allows 10GB. What am I doing wrong?
make sure u r formatting in NTFS format since FAT format does not recognize big drives. u can try to use third party software and still do it in FAT32 as long as it is under TB.
Nov 07, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Usb connector broke on hard drive
I'm gonna guess and say the connector is a plug-in type? You'll be happy to hear that YES! all data is safe (or sould be)
You simply have to open the case, disconnect the HDD from the existing controller PCB. 1 of the connectorsis a opaque plastic PLUG with 4 thick wires (12v, Gnd, Gnd and +5v) and will have to be 'teased off' by pulling straight out and wiggling side to side, and the other is a slide-on,Black or Grey 40Pin Flatwire IDE or much smaller 8-Pin SATA connector. You can simply install it in another USB carrier of the same type (IDE/SATA) or your desktop as a spare drive. Empty USB HDD Carriers are avail from MicroCenter for $20.00 Let me know how you get on or if you need further assist.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Backup copying seems at a standstill
Okay Ive got the solution for you you. You need to reformatt the harddrive initially and then when you copy your 10Gb of data you need to split it up and copy it in smaller portions, because what is causing you problems is damaged or corrupted data files that you are trying to move and the system cannot copy them. by copying your files in smaller bundles lets say 1gb or 2gbs at a time you should be able to isolate the problematic files. this method also helps to avoid congestion in your buffers and processor. thanks
May 26, 2008 | G-Technology Computers & Internet
Lost Data-Please Help
Make sure you have both USB connectors of the Seagate Y cable plugged into the computer (yes - two USB ports are used up)
It's possible that the drive is not fully powered and stuff on it doesnt show up. You need to use two from your computer to give the drive enough juice.
May 13, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
