I broke my screen but its not completely broke it has like a black space on the screen but it still plays. ijust cracked it and it has a line on it
  • 1 more comment
  • ladystar120 Oct 03, 2008
    the screen of my toshiba MES60VK (60 GB) Portable Media Player is broken and I need a remplacement but I don´t know where can I get it.
  • Anonymous Oct 29, 2008
    i broke my screen on my mes60vk and there are a few black spots on the screen anthe rest is white. I cant find a replacement screen and i dont have the money to buy a new one.
    info on where to get one would be sweet as
  • lilkk13 Oct 29, 2008
    i broke my screen on my mes60vk and there is a few black spots and the rest is white. I cant find any screens for it and i dont have the money to get a new one.
    if anyone knows where to get one get back to me.
  • 8,596 Answers
There are no replacement screens available and no repair services - live with it or replace the whole player
Call your manufacturer - they will say the same
Posted on Jun 20, 2008
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Lg reset
Sounds like the LCD digitizer which either broke inside OR became disconnected. If the impact was not enough to sustain a screen crack, and you have warranty with either LG or through your carrier, you can get LG to fix it free if there is no physical damage, cracked screen, or water damage, with your carrier, it would be the easy, just tell them the screen isn't broken, the phone is intact but the screen is blank. That is a hardware failure... they are supposed to be able to withstand some drops so it really depends on how much physical damage there is.
A digitizer LCD is not expensive and there are ways to change them fairly simple since the screen isn't cracked, you go through most LG phones via the back, remove the camera, remove a black cover that holds the sim and or memory card, BE CAREFUL and please look at youtube to see a complete disassembly of your particular LG phone.
Jul 16, 2014 | LG Cell Phones
My Dsi has a crack that you can only see when it is on
It can be repaired, however it can not be rpaired at home. If you were to send it in it would cost you about the same to buy a used one because this is what Nintendo would consider cosmetic damage. They don't tell you that the screens are one of the first things to break.
Jun 25, 2009 | Nintendo DSi Black Console
Screen broke
you may want to repair it, or at least give a little more detail about the problem, Is it cracked, do you see anything, or is the screen completely black, all of these things help determine a solution.
May 27, 2009 | Sony Ericsson W850i Cellular Phone
SanDisk Sansa View Slim 8gb Screen Cracked
I broke the screen on my e200 series 6gb so I asked Sansa tech support about it and I was told that Sansa does not own any repair or support facilities whatsover. This means that you really can't get it fixed without either buying a new one or getting it replaced altogther.
Jan 14, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Cracked your LCD screen, the black lines are where it broke.
Nov 03, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Vizio L37 37" LCD screen screen is cracked.
I agree your screen is cracked. It's smooth to the touch because you're not actually touching the LCD section of the screen, just the protective coating. The advantage of owning an LCD TV over plasma... you can replace the screen either by going to the manufacturer or some place like e-bay. It's not a difficult thing to do if you take your time and pay attention to the details.
Good Luck
Apr 09, 2008 | Vizio L37 Television
The dropped television
If it has a white line across the middle then it is probably repairable.
If the screen was cracked it could, but probably wouldn't work at all, not even a white line. The white line indicates that the vertical deflection IC has failed. Generally these IC are inexpensive and should only take an hour, if that, to replace. A good technitian should be able to repair it at a reasonable cost as well as check it over for other common problem areas.
Mar 11, 2008 | Toshiba CF36G40 36" TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
170 people viewed this question
