Question about Nokia Cell Phones
My phone is set on headset setting and I don't know how to change it back
    President:
  • 169 Answers
Factory Reset
Posted on Jun 19, 2008
Don't know how but langauage has changed from English and don't know how to change it back as all text is in language I don't understand.
use this http://translate.google.com/ it will automatically detect language ....then go to phone settings and language settings and change it ...
or better factory reset your phone check ur manual for that.
Oct 22, 2011 | LG Prada KE850 Cellular Phone
My phone is locked in headset mode and i dunno how to get it off?
Reinsert the headset and when in headset mode access the settings and change the Profile Settings from Silent to General and this should put the device back into its normal mode. Let me know if this works and if not Email me on cals2802@hotmail.co.uk and i will sort you out asap. :)
Aug 20, 2011 | Sanyo PRO-700 Cellular Phone
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
I am wanting to change my motarola H12 to my new phone and i don't know my passcode for this device how to i find it is it on my old phone?
The factory set passcode is 0000 (zero's not O's). If you changed this then you will need to reset your bluetooth to go back to the 0000
Apr 20, 2011 | Motorola Mobility Motopure H12 Bluetooth...
I have used corded earphone while I was on travel. After unpluging the earphone, The phone does not work even with blue tooth. ( no dialing tone, no sound at all) I can used it only with corded...
hi sfkimura you need to take the battery out of the phone. Next plug the headset and into the port. Take the headset out and now put the battery back into the phone. the phone got set in headset mode. You can try doing a reset of the default settings. Don 't do a factory reset it will erase your phone back to nothing on the phone. Ok hope this help
Jan 19, 2011 | LG Dare VX9700 Cell Phone
I don't know what model Motorola bluetooth headset I have but I don't know how to get it into discoverable mode to sync it to my phone.
Most Motorola headsets automatically go into pairing mode when you turn them on. If you have a light on your headset, it will be pink when you turn it on (and will begin flashing) and then change to blue. When the light is pink it is ready to pair. If you don;t have a light on your headset, it will stay in pairing mode for 10-15 seconds.
Turn your headset OFF then, (with your phone turned ON) in your phone's menu (usually) you'll go to Settings > Connectivity > Bluetooth (and select ON) Then select, Search for Bluetooth Devices and at this point you want to turn your headset ON.
It may take a couple of tries to get your phone to locate your headset but when it does it will identify the headset by the headsets model number when it locates it.
The pairing code should be four zeros. 0000.
Dec 20, 2009 | Motorola Mobility Bluetooth Hands Free...
Nokia 6085 is stuck on headset-mode. How can I
try this: get a headset connect it then disconnect it go to settings - profiles - and select another profile. If it doesnt work try to restore factory settings if you dont know the sercurity code it should be 12345 by default
NB: pls vote
Oct 24, 2009 | Nokia 6085 Cellular Phone
Getting my head set to pair
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select your bluetooth (i dont know your bluetooth model no.) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Nov 09, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth with motorola s9
I don know please give me the clear idea.
May be its posible for LG cheek with your Scoop user manual do the settings if compatable to LG it will work fine
May 26, 2008 | LG VX8300 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
