Question about Nokia HS-36W Wireless Headset
Won't show consistent blue light so I can pair with new phone Nokia N95...
I have just upgraded my phone to new Nokia N95. I have had this Nokia bluetooth headset a few years. Not used it due to changing to Sony phone. Now back to Nokia. Have lost instructions for the headset but have read up and says to hold down button for 8 seconds until blue light is consistent. Well it doesn't do that.. Can anyone help??? Single pathetic female in need of advice! :-)
Hold down on/off button and volume up button 4 over 5 seconds!!!!!!!!!!! Shazam!
Posted on Aug 03, 2008
I have nokia n95 phone. may i know the pairing code of for SBH650 for connecting
  1. Enter Pairing mode.
    • Slide the power switch on.jpg with pressing and holding [ talk.jpg ] to turn the headset on. The indicator light turns on blue and stays lit after flashing blue, red, and purple twice.
    • If you turn the headset on for the first time, it proceeds into Pairing mode immediately.
  2. Search for and connect with your phone according to your phone user's guide. (Bluetooth PIN: 0000, 4 zeros).
  3. i hope this helpfull
  4. if you think this helpfull, please rate very helpfull
  5. thanks for using fixya
Jan 24, 2011 | Samsung OEM SBH650 Bluetooth Stereo...
How do i pair sp 500 to my nokia n95 mobile
The Jabra user manual is located below - you'll need to reference it to determine which button is the Pairing button. After you turn on the Jabra, press and hold the pairing button until the blue light is solid (approximately 2 seconds). Set your phone to discover mode as follows:
Go to the Bluetooth menu under the Tools menu item
Select Options > New Paired device.
Select the device and enter 0000 as the passcode.
If you want the device to automatically pair when they are within range of each other, select the device and select Set as authorised.
That's all there is to it.
Feb 20, 2010 | Lands Phones
Can't pair up Nokia N95 with Bluetooth BH-102
Your code is most likely 0000, with a small chance that its 1234.
Jun 30, 2009 | Nokia N95 Cellular Phone
I can not pair a particular bluetooth device to my n95 8 Gb phone, but i was able to pair nokia's model. is there any reason why other type bluetooth devices won work with n95 nokia 8 GB cell phone? How...
jus change th settings of ur bluetooth on ur device an on th other device an try to pair it.. so tat u may recover tis prob... kindly rate me.... thank you...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Supertooth btslbc3
Hope this helps..............
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
By now, you should be connected to your device. Always remember to close the microphone before you leave the car.
Otherwise, it will slowly drain the battery. If you want to reconnect, just simply open the microphone.
Make sure you turn off your phone once every 2 weeks to reset the phone memory. This will help give a better
performance and clearer sound.
Oct 30, 2008 | Radio Communications
N95 will not pair with Philips shb7100
The Philips tech-support asked if I pressed the connecting button on the blu-tooth dongle long enough or until it blinks back and forth from red to blue. This takes 5 s of pressing. After this the connection worked just fine. You can actually read this in the user manual too...
So don`t just start the SHB7100 when you pair it with 95, keep the button pressed down until the light shifts from blue to red and back after which you can enter the code 0000 and Voilà!
Sep 30, 2008 | Nokia N95 Cellular Phone
I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
Jul 14, 2008 | Sony Ericsson HBH-610a (Auto Pairing)...
Nokia N95 Bluetooth
I have just spoken with 3 as I had the same problem with my Nokia N95.
The solution is:
Menu
select Tools
select Bluetooth
at top option blue tooth on - select right hand navigation button
it will say (no paired devices) select Options and select new paired device this will then seach for other blue tooth devices.
Good luck everyone
Jun 09, 2008 | Nokia N95 Cellular Phone
N95 blue tooth pairing
remote sim (off)
That should be ON
Dec 14, 2007 | Nokia N95 Cellular Phone
Nokia HS-36W Wireless Headset Logo
220 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
