Question about Kenmore 62602 Electric Dryer
Clothes Dryer The dryer runs fine and heats well. It does not stop at the preset time. I have checked continuity on the timer & thermostats. I have looked at the heater box and it does not seem to be a problem. Any ideas on what to look for next?
    Novelist:
  • 161 Answers
If it has a timer the motor is probably bad. This is not usually available seperately and the whole timer must be changed. This is not always worth it as the part can cost around 100 dollars
Posted on Jun 29, 2008
Hi-Limit Thermostat
Hi Frank Liles..
Here are a few causes and things to check
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork .
This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 17, 2012 | Bosch Nexxt WTMC3321US Electric Dryer
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
Heating Element
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Taking a long time to dry.
Hi dawansd
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
May 25, 2011 | Dryers
The dryer heats up but doesnt dry the clothes... what could be the problem
Hi rissa306
Clogged Vent
Heating Element
Cycling thermostat
May 23, 2011 | Dryers
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
Heating Element
Cycling thermostat
Apr 14, 2011 | Maytag MDE6000 Dryer
Dryer takes a long time to dry. How long should an average cycle take?
The normal drying cycle for a normal load of clothes should be around a hour if you dryer is 220 Volts.
Chances are you have a Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Maytag SDE4606A Electric Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Dryers
Frigidaire FEQ1442ES Electric Dryer not producing heat. Quits running part way through cycle... Lights flashing green.. Clothes never get dry. Code E95
Clogged Vent
Heating Element
Cycling thermostat
Oct 10, 2010 | Frigidaire FEQ1442ES Electric Dryer
It takes 3 cylcles to dry clothes
Heating Element
Cycling thermostat
This is a free answer, Please rate me
Oct 04, 2010 | Miele T1302 Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
