Question about Maxent MX-27X2 27 in. LCD Television
Lot of dots on the screem
I have this brand over 2 years. And for the last past 6 months I shows a lots of white dots around the letters the pictures. Sometimes I turn it of for couple seconds it disapears but it come back right way.
thanks for your help After one minute the whole screen turns into colored dots.. No menu or channel is visible. Turn it off off for long enough and picture reappears for about a minute.
  • 4,889 Answers
This just means some kind of over heating problem... If you let me know what you mean b long enough i can have a clue to this...
Posted on Jun 19, 2008
  • eagle338
    eagle338 Jun 25, 2008
    Any progress?
    Master:
  • 848 Answers
Your picture tube is not working properly better replace it
  • 2 more comments
  • gopinath pasupathy Jun 25, 2008
    you better check the smps in your tv
  • gopinath pasupathy Jun 27, 2008
    have you gone through the inverter ...........remove electromagnetic particle in and around your tv
    if your problem is still not solved ........consult some technican in your locality
    After one minute the whole screen turns into colored dots this indicates that your picture tube is gone
    Genius:
  • 1,847 Answers
Try change the aspect ratio.
  • Legin Varghese
    Legin Varghese Jun 19, 2008
    tyry change the resolution and reload the setting factory.
  • Legin Varghese
    if still nogo the Lcd screen is not working fine. contact the service tech.
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
My panasonic plasma has spots of bright colors where they shouldn't be.
If its four years old that is about the average lifespan of one of these sets; a guess would be either voltages drifting or off in power supply or one of the signal boards that processes information is going bad.
Mar 14, 2012 | Panasonic Viera TH-50PZ85U Plasma TV
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
White dots in the screen of my Samsung DLP HLT-5075S
This problem cause by DMD chip has been defective. This chip consist of over 2 mil mirrors tiltling to make picture. Some of the mirror does not function causing white dots. If you are in Cali, Orange, Sandiego or near by. Email me at: vinhson65@hotmail.com so I can come and help you. This replacement need skilled technician to relace as it was inside the DMD board.
Aug 14, 2009 | Samsung HLT-5075S Television
Toner Low Light on within 2 months of replaced toner cartridge
Yields for cartridges are based on a page being only 6% covered. Most letters are about 10% coverage. If you print anything with lots of print (especially bold) your yield will reduce drastically. The same thing goes for pictures.
Nov 25, 2008 | Dell P1500 Laser Printer
I'm not familar with that brand, but would check for bad solder connections by tapping the side of the set while it was on to see if the dots would come and go. If that has no effect, then it may be cheaper to replace it.
May 23, 2008 | Maxent MX-27X2 27 in. LCD Television
Scanning B+W shows dots
Don't use Descreen. That is for scanning things such as Magazines that, when looked at very close, appears to have a lot of little dots that can cause a moire pattern when scanned.
Apr 06, 2008 | Canon CanoScan 8400F Flatbed Scanner
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Maxent MX-27X2 27 in. LCD Television Logo
137 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
