Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
NAT i am trying to open my NAT which is currently MODERATE for gameing and i cant find out how. Could you please direct me as to what i need to da to open it.
  • callaway106 Dec 28, 2008
    hi I also have the same problem at the moment to make full use of xbox live have to attatch an ethernet cable straight thru to xbox 360 and it works fine but then no one else can go on line.
    I have had a go at changing the nat settings but couldnt do it then I tried port forwarding which I gave up on as It seemed rather too complicated for my very limited knowledge of all things computer related .
    So if anyone has got the time to expalin how to do this in a way that a numpty like me can follow it would be very much appreciated.
    Many thanks
  • 854 Answers
A. Determining the IP Address and MAC Address of a Computer/Game Console (PS3, XBOX, Wii, etc...):
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
NOTE: Port numbers can be provided by Tech support of each Console game Manufacturer..You can call them first...
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Apr 26, 2009
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I went on a trip and connected to a network with a moderate NAT type. When I got home I tried to connect back to my original network which is usually open and it didn't switch back to open. I connect using...
var YAHOO = {'Shortcuts' : {}}; if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts '' {}; YAHOO.Shortcuts.hasSensitiveText = false; YAHOO.Shortcuts.sensitivityType = []; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = ""; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "ross.haller@yahoo.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.version = "2.10.0"; YAHOO.Shortcuts.annotationSet = { "lw_1299607050_0": { "text": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "extended": 0, "startchar": 286, "endchar": 363, "start": 286, "end": 363, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "capAbtScore": 0, "abtScore": 0, "csScore": 0, "prismaScore": 0, "spectrumResolutionScore": 0, "conceptScore": 0, "type": ["shortcuts:/us/instance/identifier/hyperlink/http"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "metaData": { "linkHref": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "linkProtocol": "http", "linkRel": "nofollow", "linkTarget": "_blank", "visible": "true" } } }; YAHOO.Shortcuts.annotationSetID = "1eac068650c8d27415163f15165866e5"; http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360
This is what I did.
Feb 19, 2011 | Microsoft Xbox 360 Console
I went on a trip and brought my console and connecetd to a network with a moderate NAT type. When I tried to connect to my original network which usually has an open NAT type it would not switch to open...
Thats odd I know I have a moderate because I'm using a wireless 360 network adapter and my brother has open as he uses a ethernet cable. Also maybe if your bro unhooks his maybe yours will be open and his will go to moderate.
Feb 18, 2011 | Microsoft Xbox 360 Console
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
Cant get on cod mw2 online keeps getting stuck on the fetching playlists screen
what is your nat type which is located on the main menu of cod mw2 online?
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
NAT from moderate to open (xbox 360)
You need to open ports for that game on your router. Nat can't be disabled, make sure the correct ports are properly forwarded on your router. Contact the game manufacturer for the port listing.
Aug 21, 2008 | Computers & Internet
Xbox live connection: My NAT
its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
post more details of your router and what you have tried.
also you cant go far wrong visiting here
http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide2.php?department=Home
Mar 10, 2008 | Microsoft Xbox 360 Console
How to Open NAT?
Look for a setting like "Virtual DMZ Host". It's hard to tell for sure without knowing the make and model of your router.
Jan 14, 2008 | Dell TrueMobile 2300 Router (000001)
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
159 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
