Question about Minolta Maxxum 7000 35mm SLR Camera
Will not load film
Keeps blinking 0 and will not do anything else. Had a new lithium battery put in, and thats when it started.
  • Anonymous Nov 23, 2008
    i did the same. put in some rechargable lithiums then it stopped taking pix and rewinding? any ideas?
  • Anonymous Mar 21, 2009
    We can't
    Problem Solver:
  • 17 Answers
Try holding down the ISO buttun, and resetting your ISO with the up/down buttons behind the shutter release. That may help.
Posted on Nov 08, 2008
Is the lithium positive side down?
Posted on Aug 25, 2008
I recently put film into my camera and it was all loaded up and working but today when i turned it on, it made this weird sound and then the film count went back to 0 and the word that said film was...
Try changing the film,I own a Pentax and experienced the same problem.I threw away the previous film and loaded it with a new one,it worked fine.
Thank You.
Feb 22, 2011 | Minolta Maxxum 7000 35mm SLR Camera
I have a 35mm nikon camera. I've changed the batteries but the film won't load. how can i load the film?
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
Aug 06, 2010 | Nikon F80 35mm Film Camera
The zero (0) keeps flashing on my camera, it says 200 at the top which i think is the speed of the film but it wont let me take a picture. the camera is minolta 505si super DYNAX, help please!!
This is a bit late but it might help!
The manual says this:
If the film is loaded incorrectly, 0 will blink in the frame counter and the shutter will remain locked.
Open the back cover and repeat the film loading steps.
Good luck.
Apr 25, 2010 | Minolta Photography
Blinking "0" -- Doesn't Shoot
Try new battery.
If still not working try opening back cover in dark environment see if camera film will reset.
Mar 08, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Blinking film on screen.
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
Sep 03, 2008 | Minolta Maxxum 7000 35mm SLR Camera
HELP!!!wont take pics
could it be that your film isn'y loaded correctly? On my camera it will say 0 until a new roll of film has been unserted correctly.
Jun 14, 2008 | Minolta Maxxum HTsi Plus 35mm SLR Camera
My minolta sightseen camera wont take pictures?
The blinking zero would indicate that the film has not loaded but the cartridge is in place. The camera won't do anything when this occurs. Try opening the film door and load the roll again
Jan 14, 2008 | Photography
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
Minolta Maxxum 7000 35mm SLR Camera Logo
195 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
