Question about Brother MFC-8220 Fax
Fax in memory
How do you get the phrase "fax in memory: 60" off the screen? I don't know how to check for this on the menu.
  • cs26 Nov 20, 2008
    I have the same problem - unpluggin for 10 seconds did nothing - message still reads:
    FAX IN MEMORY: 60
    Isn't there an option in the menu to clear the memory? I have not be able to find it.
    Thank you for any help you can provide.
    Genius:
  • 2,120 Answers
Try unplugging the machine for 10 seconds
Posted on Oct 25, 2008
I can't erase the faxes I already send
Hi There,
While not as popular as they were before the Internet became a principal means of business communication, fax machines are still an essential item in many offices. They are particularly useful on business documents when a signature is needed. Canon makes a number of fax machines that use both ink-jet and laser technology to receive and print documents. Most fax machines store incoming faxes in memory so you can reprint them, but occasionally the memory becomes full resulting in an error message. Your Canon fax machine's memory can be cleared quickly and easily so you can start using it again.
Instructions
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
Nov 27, 2011 | Canon Pixma MX410 All-In-One Printer
Memory is full. i don t know how to clear memory to fax
Here is your solution:
    • 1 Click the "Menu" button.
    • 2 Press the arrow buttons to scroll through the options on the screen. Select "MEMORY REFERENCE" and click "Start/Copy."
    • 3 Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
    • 4 Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
    • 5 Click "Stop" to finish.
To clear only some documents from memory, click "#" instead of "*" in Step 4. Follow the instructions to select the documents you wish to delete.
More can be found here:
http://www.ehow.com/how_7259282_clear-memory-canon-fax-machine.html
Jun 10, 2011 | Canon PIXMA MX300 All-in-One Printer
Hi I am getting an error message 232 on my HP Laserjet 3055 - it says on the screen that it is low on memory but I can't find where to reset the memory if this is the problem. Thank you
Perform the following to clear the fax memory:
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
As far as I know, there is no option to turn this Fax Caching option off.
Dec 15, 2009 | HP LaserJet 3055 All-In-One Printer
My LJ 3055, it says memory is low. Pls let me know how to solve it
This can happen if your fax memory is full.
Clearing the fax memory Perform the following to clear the fax memory:
Dec 03, 2009 | HP LaserJet 3050 All-In-One Printer
OUR FAX SAYS 98% MEMORY FULL SOMETIMES WHEN THEY TRY TO FAX SOMETHING. HOW DO I CLEAR THE MEMORY? NATALIE
Press Menu, 2, 5, 2. The screen prompts you to choose a fax setting. Press <-- or --> to select OFF then press SET. If there are faxes in memory when you turn Fax Storage to OFF, the LCD prompts you to erase faxes in memory. If you press 1, all fax data is erased and Fax Storage is turned OFF.
You may want to enable Real Time TX so you can send fax without using memory. (Under FAX-SETUP SEND-REAL TIME TX)
You may also disable Fax Storage if you don't want to store incoming faxes in memory for remote retrieval (Under FAX- REMOTE FAX OPT-FAX STORAGE)
For effective use of the memory, you may also clear the caller IDs stored in the memory. Press MENU, 2, 0, 2 Press the arrow keys to display # then press CLEAR.
Hope this helps!
Jul 08, 2009 | Brother IntelliFAX 4100 Laser Fax
There are 60 faxes in memory and need to print them....HOW?
print out a help list. you can do this by pressing the reports button the help list will come print it out let me know if you figured out
Jan 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Cannot receive fax ...
Many fax machines have little internal buffer memory and the memory serves to receive a paket of signals which arrive faster than can be printed but when it is full, it may pause so the printing portion can catch up.
Check your manual for the phrase 'buffer memory' to see if they discuss why and when this might happen.
It's possible that the machine is still on line and has just paused waiting for the buffer to reduce its contents.
May 21, 2008 | Brother FAX-575 Plain Paper Thermal
Fax in memory
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Oct 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
How do I get it to print docs in memory?
Does the fax machine produce a copy? If there is a paper jam/toner error, this needs to be sorted first. What is on the display?
Aug 20, 2007 | Brother IntelliFAX 5750e Laser Fax
Brother MFC-8220 Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
