Question about Dryers
Filter light flashing on bosch exxcel condenser, repeatedly.
Hi - i have a 3 yr old bosch exxcel condenser and today the change filter light keeps beeping. i haven't got the instructions due to a house move. can you help? i have removed the fluff from from the front draw filter, but it still says theres problem. Many Thanks Caroline.
  • Anonymous Apr 17, 2009
    Repeated "empty filter" light and beeping despite filter being clean.
  • 525 Answers
This should help you find a manual.
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
I've got a 2 yr old Bosch Exxcel dryer but its in my garage and we've recently had unprecidented cold weather with night temps of -12C The dryer seems to work fine but it keeps stopping after one cycle...
Sorry to read about your problem, I hope this helps you out.
yes and it has to be around 35 to 40 to defrost...may take 3 days at that temp
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Bosch Dryers
Keep getting error f17 on my bosch classixx 6 washing machine
My old Bosch only had a filter in the machine (where the hose attaches. My Exxcel has a filter IN THE HOSE at the tap end too. I removed that one and it made a big difference !
Dec 17, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Filter lamp flashing
The condenser has two "channels" one for the moist hot air that are easy to clean and inspect. The other flow is perpendicular where cool air drawn from outside and passes through. These channels, viewed from the side can get blocked over time with dust/fluff. I blasted mine with a pressure washer and it was obvious from the change in light when looking through it that it was clogged before I blasted it.
Sep 18, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Dec 07, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Dryers Logo
592 people viewed this question
Top Dryers Experts
