Question about Star Logic 17" LCD Monitor
17'' monitor whte screen power light on
I have a 7'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there. i turned it off it just a white screen came up. i hooked up another monitor and it worked fine
  • debi8 Aug 18, 2008
    monitor went white and power on button just blinks
Have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Posted on Aug 14, 2008
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen just went blank and power light stays
THE PWER TRANSFORMER MY NEED TO BE CHANGED, DUE TO A DECREASE IN AMPERAGE.
Jul 01, 2009 | BenQ FP71G+ 17" LCD Monitor
During use playing games the screen suddenly went black; i operate two monitors simultaneously and the cable works fine on the other monitor and both graphics cards are working, any ideas on how to fix it?
Hi, if you loose video on both monitors, that means there is a problem with the video cards. I guess you already tried to update the video drivers to the latest ones, so the only thing remaining is maybe an hardware problem with the video card. Try to play your game at a lower screen resolution and see what happens. Also, if you have a flatscreen monitor, try to lower the refresh rate at the default 65Hz or 70Hz. If after 30 min or so you still loose your image, make sure the monitors are still powered (usually the green light will turn orange awaiting a singal to open and turn green then) Some video cards got some issues with heat after a certain amount of time. Something about GNU but i'm not 100% positive. Anyway, in that case, you may have to replace your video card, god of waranty please be with us! good luck
Jun 04, 2009 | BenQ FP71G+ 17" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
17" Starlogic Flatscreen LCD monitor has line across the screen
This problem is called dead pixels. You should try to return it to the seller. If the warranty is still valid they will replace it with a new one because LCD screens are extremly hard to fix.
Oct 27, 2008 | Star Logic 17" LCD Monitor
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
Starlogic monitor
I been working on lcds for some time and what I find is caps in power supply dry out over time. If you can open case and see if cap pop out at the top of it. thats your problem...cybrg0000
Oct 21, 2007 | CTX S762A 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
1,103 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
