Question about Acer Aspire 5500 5570-2609 Laptop
Acer laptop (aspire 5570z series) won't charge/turn on
My laptop doesn't turn on anymore. At first it was just having problem s charging, but now it won't charge at all. So now that the battery is dead, it won't come on at all (even if u take the battery out and try to just run t eh laptop on just the outlet). It seems that a componenet in the side of the laptop that feeds the power to the battery (or the laptop itself when the battery is remove) is malfuctioning. I was told it would be cheaper to just get a new laptop than fix it. That would really be a drag. Anyone know if i can fix it or if maybe Acer has a product that I can charge the battery by itself (externally) and then hoefully put the battery back in and power the comp?
  • 6 more comments
  • fatsoo475 Jul 04, 2008
    My laptop won't even turn on. When I plug it in with or without the battery, the front green charge light comes on but no response to pressing "power on".
    Acer Aspire 5570z
  • nauderer Jul 15, 2008
    My acer notebook have the same problem. It is not charging the battery anymore. I had tested the voltage on the motherboard, it is giving me 19.5V on the jack (backside), and on pins 2 to 5 (I guess) on the connector to the motherboard when the circuit is separated from motherboard. When I put it in its place, the voltage goes to 1,7V~2,4V, and the motherboard remain dead. I tested the power supply and it is good. It seems that some component is in short to ground, but no component is overheating (they are all very cold).
    I don´t want to buy a new NB, if anyone has the answer, please tell us.
  • Anonymous Jul 16, 2008
    I went to the store where I originally bought the laptop less than a year ago, and with much time wasted, they decided it was the battery that was the cause of my troubles. Well I came back home and took a look at it myself- turns out the pin where you plug it in is loose. My dad said he'd want to fix it himself- I've searched the internet and so far I've come up with the solution that it needs soldering to tighten it. (It would be a LOT of trouble to send it out, as Acer suggested, to the US and get it back- and I have high doubts that I would actually receive it back in time for school). Anyone have any idea how to open the laptop without damaging it- an informational websites, perhaps with pictures to aid the process. (My dad's a little apprehensive to open it himself because if he damages it, and worse comes to worse, if I do have to send it to Acer, we worry they won't fix it).I guess until I find a better solution I will continue to plug and pull the cable at different angles / propping it up with other household objects. Had I known this was this common a problem, Acer would not have been the route I'd have taken.
  • mphamm Aug 03, 2008
    Computer went off while surfing the web. Can't get it to power back up. When we try the power and battery lights both blink (yellow) a couple of times and then go back out. The power cord light is green, as always. Could it be the battery? Can you wear a battery out by leaving the laptop connected to the power cord after it has been fully charged?
  • Zephid15 Oct 30, 2008
    it stays at 4% and says plugged in, charging but never progresses above 4%. i have tried two different chargers and both give the same problem.
  • e234 Nov 23, 2008
    pin came out of mine also.......looked on lin e and can purchase replacement part for 28.00 but dont know how to change out. can some one tell me how to do this?
    thanks
  • xomidgie33xo Dec 05, 2008
    mine just wont charge. it always says either 0%, charging or 3% plugged in, not charging
  • LizzieKou
    LizzieKou Apr 15, 2014
    Had the same thing wirong with my first Acer after only using it for 6 months. Had to scrap it for parts. A friiend had the same thing wrong with his and gave it to me to fix and keep. Nothing seems to work. Got myself a Dell my first Dell laptop 6 years ago after the problems with Acer laptops, Dell still works great up to now . Upgraded the HD and memory.
    Problem Solver:
  • 18 Answers
I have the same piece a junk,the poor design of the power conector allows the barely soldered center pin to come out with the charging conector,mine lasted about a year,it was tight when it was new, have always been very careful with it and it still broke ,what a joke ,If you pull the pin out of the conector slightly then put it in slowly until you see the charge light go on in front of the computer,it wil charge
Posted on Jun 30, 2008
  • Beamvacman Sep 17, 2010
    here I am years later still using it but had to hack a hole in it and solder onto the pc board to get power past the sad connector ,airport security wont let me carry it on the plane , mine also says less than 10 percent available and never charges ,just needs a new battery
  • Beamvacman Apr 11, 2011
    Got a new battery on ebay from hong kong for 25 bucks ,delivered by mail to canada ,works great ,charges to 100 percent and lasts over 2 hours
Junk it as I did. Not worth the effort and money. When the first one broke they told me $400 to fix it. Get a Dell!
Posted on Apr 15, 2014
    Problem Solver:
  • 28 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
4sd5
Posted on Jul 20, 2010
    President:
  • 1,257 Answers
Visit the nearest acer shop and ask for a new battery for your laptop.or ask for help and support service .new laptop will cost you much ,so go for repairing your present laptop if only you have a power problem..
Thanks for using fixya
Posted on Jun 19, 2008
    Genius:
  • 2,028 Answers
Your pproblem lies within the power management chip located on the motherboard. The motherboard needs to be replaced. Besides replacing the laptop, your other (cheapest)option is checking Ebay for a motherboard for your machine. If you have the patience, I recomend watching Ebay and bidding at the price you want to pay, eventually you'll get the bid.
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Please post the step by step process of turning on my laptop acer 5570z.. (powerswitch problem) thanks in advance and more power
Hi
Have you plugged in your power cord to the electric socket so that you can charge the battery
using the laptop with the power cord in while it is charging
so if there is not charge in the laptop at all maybe plug in and turn on socket switch
and leave to charge for an hour or so
then try to start laptop again
hope you can sort it
good luck
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
Unpluged my Acer 5570z computer and now it wont turn on
You may have a bad battery.
Does the battery icon in the bottom right part of the lask bar say it is charging when you have it plugged in?
Jan 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer 5570Z wont power on
http://support.acer.com/ you should find all the answers to your Question at there support site
Aug 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire 5570z
don't worry about it! A lot of chargers blink. Mine does, it just means its charging, and no not having a battery won't affect it
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Drivers xp for acer aspire 5570z
you can download it from www.acerpanam.com.
Find the driver under these models
Aspire 5570z = Aspire 5570 = Aspire 3680 = Aspire 5580
Apr 09, 2008 | Acer Aspire 5570-2758 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
2,418 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
