Question about Sony KP-41T65 41" Rear Projection Television
My alignment is off on the picture
I'm not sure what happened. We have a Hitachi ultravision digital big screen TV and yesterday it was fine. Today I turned it on and the picture is not aligned! I'm not really sure how to describe it except that it looks a little 3D and the red color is showing a double image to the left of the image. I've tried all I can on the menu like the "magic focus" and nothing is working. Please help! Thanks
  • luckypollo Jun 20, 2008
    It is a 53FDX20B. I have its serial number too if you need that. We bought it June 2003 so it is exactly 5 years old. Thank you SO much!
  • Sony Master
  • 8,617 Answers
If you can reply to this same post and Include your model number of your Hitachi I can assist you with what you will need to get the set operating properly again, as its your Convergence amp Ics Its a very easy an inexspensive repair that you can do yourself and save about 400.00
Posted on Jun 19, 2008
  • Sonny Berry
    Sonny Berry Jun 20, 2008
    you need to replace bothe convergence Ics they are STK392-110 they are located on the far right side of your set looking in the rear mounted on a large aluminum heat sink. You can get new replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link
    http://servicemanuals.vstore.ca/
The TV has sound, can see TV menu screen, but no picture. We had a storm and this happened afterwards...
Make sure your devices hooked up to it still work (or are turned on). If it has a menu and you can change the inputs, its probable that your T.V. is fine.
Jun 16, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
Hi! my tv hitachi 50v500a ultravision had problem the screen of the tv have big red cloud
There is no solution - eventually the entire picture will turn blue. It's out of warranty and replacement of the light engine is way too expensive. Start shopping for another tv - I did
Dec 24, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Double Picture
Goto menu and look for convergence control and realign colors.
Sep 22, 2007 | Hitachi 57G500 57" TV
Sony KP-41T65 41" Rear Projection Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
