Question about Asetek COMING SOON WaterChill Xtreme Base Pump - 12V w/ 1/2" OD Fittings
Water pressure of hot tap gone.Don't know if related but was rearranging storage around pump/immersion in cuboard could i have done something to damage the pump?
    Sergeant:
  • 458 Answers
Look for a handle and see if you closed a cut off valve or pinched a hose if it has one. If there are no leaks you probably did this.
Let me know if you need any computer help also. Please rate this as a FIXYA if the problem is solved.
Posted on Jun 26, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Do you still need help? My ratings and
    questions keep getting tampered with, so I do
    not know who still needs help. The site
    people that run the site do not care. I am
    sorry for not getting back with you sooner
    than this. We had a death in our family and I
    have been out of town.
    Please rate this as a fixya if I have helped
    you. I need all of the fixya's that I can
    get. A thanks for trying score will hurt me though. Please lock the vote. If I could not help, it does not classify as a bad answer or solution. We are working for free here. Points matter a lot to enable us to answer paid questions.
    This used to be my score.
    85.09%, 160 Votes
    ? Solutions: 407
    ? Questions: 5
    ? FixYa!: 47
    ? Helpful: 35
    ? Thanks for Trying: 42
    ? Inappropriate: 1
    ? Not Rated: 275
    This is with tampering.
    83.11%, 111 Votes
    ? Solutions: 454
    ? Questions: 6
    ? FixYa!: 24
    ? Helpful: 23
    ? Thanks for Trying: 33
    ? Inappropriate: 0
    ? Not Rated: 360
    As you can see I have had someone tampering
    with my score. I need all of the help that I
    can get from the people that I have helped.
    If I have helped you, return the favor and
    please help me.
    You can click on my name in the future for
    help. If you still need help, please ask me a
    more detailed question.
    Thank you and have a nice day.
Why would I get hot water from only one tap in the house, but still have pressure from all other hot taps, just no heat in the water
hi,
has anyone done any plumbing work to your original plumbing? like a pex upgrade? ive seen rookie installers get the runs backwards and have issues like that. do you have a hot water circulation pump system? one of your zones might have went out, get three estimates from reputable plumbers.
Aug 05, 2017 | Water Water Heaters
Pressure gauge drops to zero when hot tap turned on
There are multiple types of systems that use the configuration you are talking about. We have no way of knowing what the system is but there is obviously a supply problem. Either the pump is not working correctly or the water supply has been constricted.
Jan 10, 2016 | Water Water Heaters
I have an Atwood water heater G6A-7E, heater heats up but no hot water flow after 15 seconds...Flushed system with water and air, put water to it and the hot water flow stops after a few seconds....
First check that any by-pass valves are in proper position. Remember, cold water has to enter in bottom fitting at back of tank, and hot water comes out at top fitting. Thus any valves that may be there, need to be in open position, and any valve between those 2 lines will need to be closed. If all valves are in proper position and working as they should, I would suspect you have a faulty check valve between top (hot) line fitting and tank. One easy way to check that before replacing it, would be to shut incoming water source off, whether running off pump or hose attached outside. Then relieve all pressure in system by opening taps until all pressure is gone. Now, go outside and open pressure relief valve carefully ( in case it's hot ) and make sure pressure is relieved there as well. Now, carefully hold pressure relief valve open while you have someone turn water back on, and see if you get good flow from pressure relief valve. If you get good pressure coming out of there, that tells you your tank is getting full, and you have water coming in as needed, so problem has to be on hot side ( top fitting ) and/or onward from there, which would be check valve fitting at top next to check. Remove the check valve and If you don't have a new check valve to try it, just put a short galvanized 1/2" pipe nipple in there for now if needed and that should do it, just attach your fitting directly to nipple. Before you do this, make sure you have removed all aerators etc on taps that may be plugged and tested pressure that way as well just in case. I have seen all of them plug up at same time before. If you remove them and get good pressure, then problem solved.
Nov 06, 2011 | RTO Atwood Water Heater - 6 Gal LP
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
I have a grundfos mq 35 pump to boost pressure in my hot and cold system. due to loss of water recently pump ran dry and shut down. when water returned the system was restarted and pump reset. we now get...
There was possibly some damage done to the pump while it was operating dry and it in now not able to deliver the required flow of water. Pumps wear very quickly when allowed to run dry, even for a short time.
Jan 02, 2011 | Grundfos JPS4 1 HP Pressure Booster Pump
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
When adding air to a pressure water pump ,i
Sounds like the bladder is gone or inproper air pressure in water storage tank.
Bladder goes bad check it out with step 1
1-
One way to check for sure with everything hooked up. The air valve on top of the tank if pressed you will get water out of the valve which should be only air. This will let you know it should replaced.
If Tank bladder is low in air and not water coming out.
2-If it checks ok put an air gauge to tank to check the air pressure, with a standard 40 gal tank you will have 28 psi of air in tank for it to function properly.
May 21, 2010 | Plumbing
Low pressure from immersion heater to mixer taps on bath can i fit a pump on the pipe work leading to the bath
You need to have an higher head of water on the tank that feeds the cylinder that the immersion heater is fitted to. Put the tank on a framework say 3 foot above its present level.
Regards
Alan Hood
ami-man
UK
May 10, 2010 | Plumbing
Hi! My hot water taps from the wash hand basin and mixer bath has low pressure. I`ve got a combi boiler in the first floor. Can I install a single impeller pump connected from the hot water outlet from the...
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
Apr 04, 2010 | Plumbing
Jenn Air Ice Maker Ejector Fingers Freeze Up
Hello, Yes you may be on the right track. Some manufactures like Jenn-Air, Viking, Sub-Zero, etc. require a higher inlet water pressure across the inlet solenoid valve to close the diaphragm after the ice machine stops calling for water. There are multiple solutions. But first, check the water pressure to your home to make sure you have 65-70 psi of pressure entering the home. Here is a link to our web site for a reasonably priced solution to increase the discharge working pressure from your RO System storage tank to the Jenn Air: http://www.puresafe.com/RO/html/eps-3tpp.html This is a modification that can be done to your system. It is a Patented Piston Actuated Permeate Pump that relieves the Permeate or Pure Water "BACK"-Pressure when the pure water enters the storage tank so the tank can store more water and build more working pressure. You could also increase the size of the storage tank, increase the size and daily production of the Membrane Filter to recover the tank water quicker, or add additional storage tanks for more volume of storage. Another method would be to use an "Atmospheric Storage Tank" with the RO System, and a Pressure Delivery Booster Pump to **** the water out of the storage tank and Pump it to the required location under higher pressure and flow when compared to the Conventional Pressurized Bladder Tank that you own now. The drill down path to our site for this information would be: www.puresafe.com, Purification, Reverse Osmosis, Residential, Pump Assisted Reverse Osmosis, EPS-3TPP, or other systems on that page. Hope this helped. Victor Kernes
Jun 25, 2009 | Jenn-Air JCD2389G Side by Side...
Asetek COMING SOON  WaterChill Xtreme Base Pump - 12V w/ 1/2" OD Fittings Logo
82 people viewed this question
Top Asetek Computers & Internet Experts
David Payne
David Payne
Are you an Asetek Computer and Internet Expert? Answer questions, earn points and help others
