Question about Soleus CFM-40 Dehumidifier
My dehumidifier will no longer collect water
I purchase a soleus air dehumidifier last year. It worked perfectly. However, this year when I took it out from storage over the winter, it stopped collecting water. I cleaned the air filter, but it still will not work
SOURCE: Dehumidifier does not collect water.
I had the same problem. I just narrowed it down to the humidistat by wrapping it in a baby wipe. It runs smooth now and fills the bucket....I'm off now looking for a replacement.
Posted on Aug 13, 2007
SOURCE: Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Posted on Apr 21, 2008
Illeagle
  • 525 Answers
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
Why is it running but not dehumidify - taking water out from air
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 29, 2011 | Soleus CFM-40 Dehumidifier
Doesn't dehumidify at any temperature any setting, compressor works, good air flow.
heatman101
Jun 14, 2011 | Soleus CFM-40 Dehumidifier
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Soleus Air Dehumidifier Model CFM-25E has stopped working after about 1-1/2 years.
heatman101
Apr 21, 2011 | Soleus Dehumidifiers
Our dehumidifier is no longer pulling moisture out of the air. I took the back off and the fan is still running. So motor or condenser? And is it worth fixing? The machine is approximately 6 years old.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Nov 28, 2010 | Kenmore 54501 Dehumidifier
My 40 pint Soleus dehumidifier doesn't pull any water into the tank even though the fan blows normal.
heatman101
Jun 18, 2010 | Soleus CFM-40 Dehumidifier
My soleus CFM40 has stopped dehumidifying. Just blows cold air. I think the heat element that dries the air stopped working. Do yo agree?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 02, 2010 | Soleus CFM-40 Dehumidifier
Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Jul 09, 2009 | LG LHD45EL Dehumidifier
Does not collect water .. fan runs
If it is not blowing out air from front grill then fan is burned out and needs replacing - $50 do-it-yourself (lots of disassembly) $100 for them to do it. Is it still in warranty? (1-2 years for fan/sensors))
Jun 24, 2009 | Soleus CFM-40 Dehumidifier
Soleus CFM-40 Dehumidifier Logo
210 people viewed this question
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
