Question about Microwave Ovens
My microwave/convection oven blew a fuse. replaced it and the convection works but when I try to use the microwave it blows the fuse again. what needs to be fixed?
  • 413 Answers
Typically, when the fuse blows in the microwave, the high voltage capacitor fails and becomes shorted.
The door switches are also configured in such a way that if tampered with (in this case, failed switch or latch) the fuse will also blow. Check the capacitor first.
If you need further assistance let me know
The FixYa Team
Posted on Jun 19, 2008
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
I have a sharp R-930AK micro/convection oven that blew fuse, replaced it, it came on then blew again. Help now what?
Hello, there is a component that is pulling more current than it needs to be. I would check the microwave HV diode there could be some leakage to ground. Also, the mega-tron tube might not be working the way it should. If the mega-tron tube is going out. Just replace the microwave oven. It is to cost prohibitive to replace the mega-tron.
If you replace the microwave oven. Please recycle your old microwave. Boy Scouts, recycling centers, some charitable organization will recycle. GB...stewbison
Sep 06, 2011 | Sharp R-930AK Convection/Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Advantium 120 blew breaker when door was closed. I reset breaker and it worked for three weeks. Breaker is blown again...when i open the door and reset breaker it works, but as soon as you close the door...
I'd suspect the interlock monitor switch is stuck, or its mounting bracket is out of adjustment. This is designed to blow the fuse if you try to run the oven while the door is open. The switch is supposed to open when you close the door. This switch is replaceable, but you should have this oven repaired by a professional. There are lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't done correctly.
Mar 20, 2010 | GE Advantium SCA1001SS Convection /...
I believe mine blew a fuse as well
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
many people have been electrocuted with an unplugged microwave due to the enormous residual charge inside.
you can now get a new microwave at walmart for fifty bucks..........why monkey with a ten year old unit.
Aug 17, 2009 | Sharp R-963 Convection/Microwave Oven
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
