Question about Canon PowerShot S3 IS Digital Camera
Plastic tripod mount
Can I replace the plastic tripod mount on my Canon Powershot s3?
  • baxtersp Jun 19, 2008
    The threads are plastic. I've read that other people have broken them, and was wondering if there is a way to replace the plastic mount with a brass mount.
  • Tim Babcock
    Tim Babcock May 11, 2010
    How is the threading in it?
  • Canon Master
  • 2,794 Answers
Thats a bummer. I don't think there is. I would check with a camera shop. You might want to try some locktite and see it that works but you will probably have to keep the tripod mount permanantly on your camera.
Posted on Jun 19, 2008
Please advise how to close the battery cover
Hello and Welcomethe Canon A560's bottom panel is reasonably flat, with a sliding door to access the battery compartment and a threaded plastic tripod mount off in the opposite corner. The battery door and tripod mount are far enough away from each other to permit quick battery changes while working with most tripods To close the battery cover first Hold it and make it Flat and then by the tip of Your thumb Press it in inner side To demonstrate it the image is given below: angel_bird_0.jpg
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 09, 2011 | Canon PowerShot A560 Digital Camera
I have broken the glass on the viewfinder of my powershot S3IS, can it simply to un-srewed and a replacement put in - if so where can I get one from?
If only the viewfinder glass is broken, you can put other one to replace it.
It could be glass but I do recommend you to replaced with an acrilic or a plastic part.
You can get it from different soruces: Ebay from a broken camera (S2, S3 or S5), or use transparent plastic film and cut it to the right size.
You don't need to open the camera completely. You will need just to remove the viewfinder rubber protector, and carefully, pull the viewfinder frame that holds the glass. There are four plastic locking tabs (two up, two down).
Best regards,
Jul 14, 2009 | Canon PowerShot S3 IS Digital Camera
Have tripod, how do I attach my SD870 IS?
just screw the screw onto the bottom of the camera
May 28, 2009 | Memorex Photography
I am in need of a replacement flash bulb for my Canon S3 SI camera. Does Canon or anyone else sell them? I am also looking for a replacement flash for my Canon Powershot S3-IS. It stopped working and I...
You can buy in Ebay a broken camera, and get the parts you are lokking for, or send them to a professional camera repair center so they are fixed properly.
Best regards,
May 25, 2009 | Canon PowerShot S3 IS Digital Camera
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Technique on taking images of baseball cards
Greetings sandb27,
Your best route to avoid flash reflection on your cards is to find a lighting situation where you do not rely on flash. I would suggest a small handheld tripod to stabilize the camera and shooting without the flash. You might also try to use the Indoor Mode. Indoor Mode prevents camera shake blur and adjusts the white balance to preserve the subject's true color when working under tungsten or fluorescent lighting.
Thank You,
Agent Dort
Go Ahead. Use Us.
Mar 17, 2008 | Canon PowerShot A560 Digital Camera
Plastic tabs on leg locks broke
yes with the original plastic locks. "junk" go to ace and you will find some differant lock slides. I did and they are not plastic!
Dec 25, 2007 | Sony VCT-670RM Tripod
Focus in Macro mode
1. Do not use the zoom while using macro. 2. When clicking the Macro button, click it again, only for 2 more seconds at the second click, it goes to 'Super macro' mode for zero distance. This works in the Canon S3 IS, I hope it will help you in the older S2 IS. 3. Use a tripod. 4. Use the timer for no movement when using a tripod. 5. Try using the manual focus, it does the trick when the camera doesn't focus automatically. Good Luck!
Aug 13, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
