Question about Casio Parts Cash Register PC Desktop
Casio cash register model # pcr202
The paper roll will not feed thru the printer. I found a small black piece of rubber that is about 1/4" in diameter and about 3/8" long that is split. I think this might be a belt. How do I fix it.
  • 737 Answers
Hi. we don't have that model here, but it sounds like the feed roller has come out. It is common in the little Epson 42 series printers. You will need to get a new feed roller. Some suppliers will only sell you a whole printer - prob around $60-80 US. ring your local dealer and see if one is available.
Mark
Posted on Jun 23, 2008
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Till roll re-placement not printing
Try turning paper around or make sure you have thermal paper if it is a thermal printer model
Jun 18, 2014 | Casio Parts Cash Register PC Desktop
How do I load the till roll into a Casio 240CR
While holding down the feed button, feed the end of the paper into the slot at the back of the printer.
If anyone is having trouble programming a Casio 240CR cash register, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_240CR_operators_manual.html
Aug 23, 2012 | Casio Parts Cash Register PC Desktop
Fix paper feeder in casio 110cr
Common problem when they get to this age. Feed roller falls to pieces. Replace whole printer to fix. Never found a supplier who will sell separate parts.
Mar 07, 2012 | Casio Parts Cash Register PC Desktop
On the screen there is a E94 error messagage on the Casio P260 cash register . How can I correct this error and reopen the cash register.
E94 is a printer error. Open the printer and make sure nothing is jammed in it.Remove the paper roll. Look for old pieces of paper stuck in the gears etc. ----------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-260 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
I have a Casio CR150 cash register. The paper wont feed through. Its making the correct noises & it will feed it i pull the till roll at the same time as pushing the feed button. Can you supply me with...
Very common problem. That's how the printer finally fails. that is basically considered the end of it's life. All the suppliers I have tried do not supply separate parts for this printer, so either replace the whole printer, or see if you can find a supplier of separate parts.
Mar 22, 2010 | Casio Parts Cash Register PC Desktop
I have a PCR202 cash reg. Works good,except it prints double about 1/3 of the time, fixable?
I recommend to get a register without the type of printer it has. The (rubberband printer) is made to last too long. usually this means the pinch roll has loosened up a bit and in those printers it costs more to repair than replace!
Oct 01, 2009 | Casio Parts Cash Register PC Desktop
Changing the paper feeding roller in a cr 110 cash register
hi. You buy the feed assembly (the whole black plastic part that holds the roller) from a dealer, then it clips into the back.
Mark
Apr 11, 2008 | Casio Parts Cash Register PC Desktop
Casio Model #PCR-202 cash register
That model is so far out of date it's near impossible to find a manual. You can find some solutions to FAQ here:
http://www.casio.com/support/techsupport/spd/pcr202.html
Other manuals (may be able to find a similar model) here:
http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
Mar 24, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
101 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
