Question about Tascam 2488 Portastudio Multitrack Recorder System
Boot Problem in TASCAM 2488
My TASCAM 2488 cannot boot up. When I start it, it says,"cannot boot. not detecting HDD correctly. Check H-W". How can I solve this issue? Thanks a lot.
  • Anonymous Apr 17, 2009
    I have the same probleme and i don't know what I can make
  • 3 Answers
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Posted on Mar 05, 2009
  • Gene Cost
    Gene Cost Sep 25, 2016
    I traded an old computer for a 2488. I planned to use it for recording live bands. I was listening to the material recorded by the previous owner when I suddenly got a system error. I figured the hard drive had crashed so I was looking for a service manual when I came upon your post to factory reset. It worked! Thanks for putting that info out there!
Hi I had the same problem and a tech from tascam told me how to reset the unit and that fixed it for me.....
Directions ; power off unit...then hold down these four buttons;
quick rout button ...shift button....send button and the shut down button...while holding these four butoons down turn on the unit ...when it says initialize let go of buttons and it should reset...
hope this helps JP
Posted on Feb 20, 2009
  • 1 more comment
  • carl  eschete
    carl eschete Nov 11, 2010
    Nov 10, 2010..(Tascam 2488)
    .I had the same problem...Thought it was the hard drive, changed it , same message..I tried the shift, send, shut down, quick route,, no luck..Tried different adapters, nothing..Also tried swapping master, slaves,, etc..Tried going straight to the hard drive with out going to Cd Rom...NOTHING!!Tried different ribbon wire(Flat one)..NADA!! Just out of a whim, my cousin had an extra CD Rom...What the HECK!!Lets try it...GUess what???BINGO!!!!It was the CD-Rom....Aparently everything has to be connected, cannot single anything out...It started, disk Detection,, reading song,, Now working, ect...I was EXTATIC,,lol..May be the same for other musicians having this problem..Cd-Roms are cheap...Give it a try and WRITE BACK...Really would like to HEAR IT WORK for other..Leave a comment ......CARL--IN-Louisiana......
  • amor333_83
    amor333_83 Jun 22, 2014
    i have qwuestions...
  • amor333_83
    please write me romanshytyak@gmail.com how you decided you problem?
When I turn on my Tascam 2488 it says Cannot BOOT !! Not Detect HDD correctly Please POWER OFF And Check H/W
Secure the connection of the hard drive by pushing if firmly or
by pulling the connection, then reconnect it again.
Oct 05, 2010 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
Where can I get knobs for a Tascam 2488 MKII. Trim knobs
I get a CAUTION sign when I boot up that says:
Cannot Boot! Not Detect HDD Correctly. Please POWER OFF , and Check H/W..." Can anyone assit me with resolving this problem
Thanks
Scott
Feb 11, 2010 | Tascam 2488mkii 24 Track Recording...
Cannot boot not detect hdd correctly power off and check h/w
Usual suspect is a faulty power adapter which is failing to provide enough power for the drive to spin up to speed. Try another adapter with the same ratings.
bd.
Jun 12, 2009 | Tascam 2488 Portastudio Multitrack...
HI I have the tascam 2488 mk11....have only had it a little over a year....has about 20 hrs. playing time on it as I haven't had time to use it.....Today it gave me the following message; CANNOT BOOT...
This is often due to the HD not getting enough power to spin up to proper speed when booting. Usual suspect is the power adapter. You might try picking up an after market one that matches the specs before going through the expense and trouble of shipping the unit back.
Feb 19, 2009 | Tascam 2488 Portastudio Multitrack...
2488 will not boot up, says not reading the hdd check the h/w .
Usually this is a problem with the Hard Drive not getting enough power to spin up properly. The AC power adapter is the usual suspect.
bd.
Oct 21, 2008 | Tascam 2488 Portastudio Multitrack...
Problem with the hdd. check the h/w
I tried everything that I can think of also, so I am going to send it into the shop. I will post what they tell me.
BR
Jul 03, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Repartition and format the hard drive. There are specific instructions elsewhere on the Internet. I did this about six months ago. I believe my problem came about after I stored my 2488 on top of my monitors - I believe the exposure to the magnetic fields corrupted the boot partition on the drive.
Apr 10, 2008 | Tascam 2488 Portastudio Multitrack...
TASCAM 2488 won't boot up..HELP!
reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
Apr 09, 2008 | Tascam 2488 Portastudio Multitrack...
before actually addressing the issue I need to know if you are sure that the unit is getting power. You may just have a power cord issue.
Oct 17, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
2,156 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
