posted by afidalgo on Jun 19, 2008
Doet front loader. First the softner did not empty and now it stops at the spin cycle and will not complete load
Best Solution
posted on Jun 19, 2008
you should have gotten an error code if a cycle does not complete.
one of the issues that can be checked for is blockage of the filter in the bottom access panel.
remove the 3 screws on front bottom of access panel ,
then remove/unscrew the large filter access port and check for debris.
some water will be maintained there so have some rags or towels ready.
if you still have any issues get the readout code on the front of unit and any other symptoms, issues ,sounds it makes.
Rating Locked! (?) afidalgo has rated this solution as Helpful
This Problem Also Relates To:
Whirlpool AWG329 Front Load All-in-One Washer / Dryer
Whirlpool AWZ410 Front Load All-in-One Washer / Dryer
Whirlpool Cabrio HE 4.5 cu. ft. Ultra Capacity Plus Washer
Whirlpool (WFW8300SW)
Whirlpool AWM6120 Front Load Washer
Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8163 Front Load Washer
Can you Help with these Washing Machines problems?
Kenmore Elite 45986 Front Load Washer
Leaking : Heating element come...
Machine started Leaking. After... Answer This...
Whirlpool Duet GHW9150P Front Load Washer
Soap not fully dispensing
I am using HE powder soap. It... Answer This...
Bosch Nexxt Premium WFMC6400UC Front Load...
Start/Pause indicator...
Start/Pause indicator... Answer This...
Haier XQG50-11 Front Load All-in-One Washer /...
Haier washing machine E2 error
My Haier washing machine keep... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
