Question about Gateway Computers & Internet
PC won't wake up.
Amber light is on and pc won't wake up. I had to unplug it and plug it back in to reboot and it worked. Today I had to do the same thing only when I plugged it back in the amber light was still on. I believe it is my motherboard but would like another opinion. Thanks so much!!
  • 655 Answers
Make power on,
see the SMPS fan from back side in CPU, if its not working, mean you have problem in SMPS or in power supply cable. Try another power supply, also make sure that socket on wall is right and the current is available there.
If your SMPS is working then try to hear beep from CPU after booting, there must be a ok beep, if no beep, then it means there might be problem in your CPU.
Thanks
Iqbal
Posted on Jun 19, 2008
Wifi wont come on
Unplug, remove battery, plug in, reboot, any change? Have you done ALL the Windows and HP updates? Open the Device Manager, open Network Adapters, is the Wireless adapter enabled, in error? You can find the driver for the Wireless adapter here, choose your OS: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=4145202&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=4145198
Mar 05, 2013 | HEWLETT-PACKARD ProBook 4520s
Amber light is on
Unplug the power cord and the USB cable from the rear of your printer. Wait one (1) minute. Plug the power cord back in. Plug the USB cable back in. Re-start your computer. In most cases, this will solve the problem. Good luck.
Jan 10, 2013 | HEWLETT-PACKARD LaserJet M1319F All-In-One...
Motorola DCT700 won't power up.
its working correct... thats sounds normal
now you just need to wake it up. turn it on using the remote supplied by your cabe operator. if anything it may be your remote that isn't working. does a "cbl" light or anything light up on the remote when you press the cable box power button? if not try to find out how to put it in cable mode and try again.
wish i had more info
good luck
Aug 12, 2012 | Arris DCT700 DTV Receiver
Computer on sleep mode,and won't wake up
try to turn off by pushing the buttom till off if that wont work do the old stand by unplug the pc from wall then turn back on the system should reboot itself an work, good luck
Aug 13, 2011 | HP Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
Dell dimension 2400 will not boot. Diag lights A & B amber.
first of all dnt take tention,
firstly remove ur all RAMs then reboot ur system. after that flash the motherboard cell.
after that reboot ur system, if yous system have same problem then plug out all hadware of ur system except VGA, RAM, Hard Drive,and key board. after this u may restart ur PC and then check it out.
hope so ur problem is solved
Aug 26, 2009 | Dell Dimension 2400 PC Desktop
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
