Question about Comfort-Aire HMH12AS-0 Air Conditioner
AIR CONDITIONNING CODE 8 TIMES FLASHING
MODELE B-HMH12AS
2002 kia sportage air bag light flashing is this current code or a latched code
The airbag code will not go away until the problem is fixed.More than likely they is a defective airbag module and you will need a scan tool to find out which one is bad.
Feb 14, 2013 | 2002 Kia Sportage
Bmw x3 2006 air conditionning system does not work properly. driver side is cold but not enough. center is lightly cold beside driver but no fresh air to passenger side. Passenger side is not cold. With...
you will have to inspect the blend doors. These are the ones that control the flow of the air in the AC duct. It is under the dashboard. There might be loose linkages or parts that you may just need fitting or a bad motor for the door.
Sep 26, 2011 | 2007 BMW X3 3.0si SAV
Problem with air conditionning it stops and a light is blonking
Hi, what you need to do is remove the panel where this light is blinking first of all. There may be a panel switch on the perimeter that will kill the power when you remove it, you will know if the light goes out. If this happens, tape it down so the unit will blink again. On the panel, or inside the unit you will see a chart for troubleshooting with a list of codes and faults on it. It will tell you to count how many times the unit is blinking, and will have a code that will tell you what is wrong with the unit. It may be a safety switch that needs to be reset, or the outdoor unit may be dirty and needs to be washed. Anyway, find the chart and go from there.Please keep me posted on this, so I can help you get it running.
Shastalaker7
A/C, Contractor
Aug 08, 2011 | Heating & Cooling
What is the ec button for? my air will not blow cold and the ec button is staying on
EC stands for air conditioning. Have you charged the air conditionning with gas. is the air conditioning pump making a clicking noise when you press the EC button.
May 30, 2011 | 2001 Mercedes-Benz S-Class
Flashing airbag light on 97 maxima. Car was in an accident, airbags deployed, replaced bags and controller why won't the light stay off
To manually check air bag codes, turn the key On and push the driver's door switch (at the bottom of the B-pillar) 5 times or more within 7 seconds of turning the key ON. Then watch the air bag light flashing codes. The air bag light will come ON for 3 seconds and then give fast flashes if there is a code. Count the fast flashes as the code. So the air bag light on for 3 seconds and then 8 flashes is a code 8 for the passenger air bag circuit. after counting code clear codes and see if they come back
Nov 22, 2009 | 1997 Nissan Maxima
The air conditionner is mounted on wall and is leaking water
The Unit must be lower at the back end and higher than the drain hose if using one.
Aug 23, 2009 | Samsung Heating & Cooling
For air conditioners is also stay at 64 i dont go up or down whit the remote why
Please elaborate! I'm unsure if your A/C will not change temperature without the remote. Some units have a "lock" which if set, will keep the unit at the same temperature & if it's only not working with your remote, my guess is that your remote is bad or the batteries are dead or placed in it incorrectly (or may have leaked & ruined the remote.)
Jul 02, 2009 | Comfort-Aire HMH12AS-0 Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Comfort-Aire HMH12AS-0 Air Conditioner Logo
41 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Ottoniel
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
