Can't remove captions - Televison & Video
    President:
  • 1,284 Answers
If you have a HD television connected to a HD cable box or satelitte box then you must disable closed captioning in those devices. The is for HD set connections only.
Posted on Jun 20, 2008
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Jul 13, 2011 | LG Televison & Video
How to remove closed caption when on direct TV
While on the channel you want to remove the captions from:
1.) Push the yellow button on the remote control.
2.) You should see an option to turn on/off the captions.
3.) Select the option "Remove Closed Captions".
Mar 05, 2011 | Televison & Video
Can't turn off closed captions or find option to do so please helphelp
hi,
u can remove the closed caption optoin by the following setup.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
Dec 26, 2010 | Philips 32PT6441/37 32" TV
How to remove closed captioning on a hitachi ultra
closed caption can also come from a cable or satellite box if you are using one--either it is from the set or the box----either can cause it.
SD TECH
Jun 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
How do you remove the subtitles?
Subtitles are controlled by 'CC". Closed Captioning. Look for a CC button on the remote or captioning.
Captioning usually is in the menu as well under 'settings'.
Closed captioning has several settings. OFF turns all captioning off. CC1, CC2, CC3 & CC4 are captioning styles. Text is for text channels.
Mar 31, 2010 | Toshiba 57H84 57" Rear Projection...
How to remove closed captioning on tv screen
Press the Caption button on the remote control to cycle through the caption options until OFF appears. If there is no Caption button on the remote, go to the system menu and turn captions off in the caption submenu.
Jan 08, 2010 | Philips Magnavox 20MT133S 20" TV
How do i remove the caption from screen on a konka tv?
On Time Warner Cable box change the Closed Caption to T3. This will remove the closed caption box when you change channels.
Sep 18, 2009 | Televison & Video
My tv has a black square in the middle of the screen.how do i remove it
thats your closed captioning. on your remote, there should be a button on your remote to remove the closed captioning or to change the captioning type. Look for the "C.C." Button. press it. the closed captioning type will change. press again and again untill there is no text or it says "off or None"...
Hope that helped.
Aug 14, 2009 | JVC AV-32D305 32" TV
Removing close caption on television
I was able to obtain a users manual online for free but I need to have a remote to remove the closed caption. Thanks for the response but I don't need to apply for an assistant plan.
May 25, 2008 | Televison & Video
Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Feb 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
