Question about Kodak EasyShare Z740 Digital Camera
Kodak Z740 I've replaced batteries several times, it stays on for 5 seconds then turns off. Any ideas
  • Karpy Jun 28, 2008
    Our z740 also shuts down after about 5 seconds. New batteries make no difference. Would appreciate your help.
  • afreeman Jul 12, 2008
    My camera will lt me look at my pics bu if I switch it to take pics it turns off
  • Kodak Master
  • 2,794 Answers
If you replaced that batteries and it isn't staying on, it should be looked at a camera shop to find out why it isn't getting any power to it.
Posted on Jun 19, 2008
Foel problem
When you smelt fuel, It was flooded. Your best bet would be to replace the spark plugs. Gas will foul them out, just like oil.
Jul 13, 2013 | 2000 Honda Civic
My 1995 mitsu eclipse is sputtering and has trouble staying on when I turn it on for the first time in more than 5 hrs. It also stalls and throws me an oil light. I've changed the spark plugs (which...
Coil battery circuit may be loose or corroded causing the recurring code/light . Which code number are you getting ? Have you cleaned the throttle body and IAC as that can cause idle issues .
Apr 10, 2017 | Cars & Trucks
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Power turns on but will not stay on .
If you haven't already...I'd try new batteries and use good ones like Energizer Lithiums. Some electronic devices are sensitive to lower battery voltages.
Jan 15, 2018 | Vivitar Vivicam T324n - 12.1mp Digital...
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Compaq Presario V2000 will not boot.
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
Power Switch will not turn my Rhino 530 HCx on
When I try to turn it on it comes up with the “rino” initialization screen and buzzes/vibrates at 5 second intervals. It never goes past this screen. Occasionally, for about 1 second a small white bar will appear across the bottom saying “0%. I’ve recharged the Li battery and got the same result. I’ve tried it while connected to the charger. Same result. I’ve tried using the optional 4 AA battery pack with fresh alkaline batteries. Same result. Did the factory reboot (page/enter/power buttons). Same – except instead of a buzz/vibrate I get the tone every 5 seconds. Have to remove battery to turn off.
Contacted Garmin tech support today (10/22) - hope to hear from them soon.
Sep 09, 2009 | Garmin Rino 530 GPS Receiver
Kodak EasyShare Z740 Digital Camera Logo
66 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
