Question about Canon i850 InkJet Photo Printer
I850 printer error message 5100
Hi I have the above error message error 5100. It says to turn printer off and start again and to check manual if problem continues. However there is nothing in manual regarding thismessage. Can you help please. I did have a paper jam a few hours previous but it printed another 20 pages or so before this message started.
many thanks
  • 1,602 Answers
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Posted on Feb 04, 2009
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
How to fix error no. 5100 on Canon MG5170. Printer message reads 'Printer error has occurred. Turn off printer than back on again. If problem persists, see the manual' but I cannot see reference to this...
Get Easy steps to Fix Canon Printer Error 5100 instantly. Watch Video to learn how to fix Error Code 5100 & 5200. Call now +44-8000465291 for instant Printer help.
Video link: https://youtu.be/p-S5aX-BqZU
Source: http://canonprintersupportnumber.co.u...
Get in touch with us:
Toll-free Number: +44-800-046-5291
Email: support@canonprintersupportnumber.co.uk
Aug 10, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Jun 21, 2010 | Canon Pixma MP480 All-In-One InkJet...
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a cannon printer mp160. I'm trying to print a document but I keep getting a service error 5100 message
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day.
Nov 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Error 5100
  1. check the user manual if you had one for that error code,
  2. and I suspect the ink level of your printer,
  3. and also check if there is any paper jam exist,
  4. disconnect the power source for 2 mins and turn on again.
  5. try to print again.
Apr 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Canon i850 InkJet Photo Printer Logo
305 people viewed this question
old marine
old marine
