Question about Philips 60P8341 60" Rear Projection Television
Conversion box Does this model require a conversion box from analog to digital
  • 2 more comments
  • genegaskins Jun 19, 2008
  • genegaskins Jun 20, 2008
    Since this set is used for local tv stations only, your answer
    regarding needing a converter box is what I needed to know.
  • genegaskins Jun 22, 2008
  • pact56198 Aug 31, 2008
    Phillips TV Serial # 25PS40 S121, is it Digital or Analog? Will I need an analog converter box to operate in '09?
  • 4,234 Answers
I hate to be the bearer of bad news, but the response given above is not correct. The only time a converter box is required is if the set uses an antenna. Cable and satellite reception remains the same. The conversion required by law in Feb 2009 effects over-air broadcasts only. The aspect ration 4:3 vs 16:9 has nothing to do with digital vs. analog.
Posted on Jun 19, 2008
  • ABRsvcs Jun 21, 2008
    Additional information:
    Check with the local stations as if they are small enough, they are exempt from the requirement for digital broadcasting. You may not need a converter at all.
  • 114 Answers
This set is a standard 4:3 projection, so yes, to receive digital, you will need a converter.
How can i tell if my advent tv manufactured in 2003 model #q2035a is hdtv ready or if i need to purchase a digital converter box?
The first question to ask is how do you get your tv signal. If you have either cable, or satellite TV then you don't need a converter box, as those companies do the conversion for you.
If you have an antenna, you will need a converter box if yout TV is an older model which is analog and not digital. If your tv is a 2003, it is analog.
Jun 13, 2009 | Televison & Video
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
Analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Sep 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Do I need a conversion box??
Hello there jimmysac77,
I've spent some time trying to find some information on your television, but am hitting a brick wall. I can only assume from this that your television is an older model, as a general rule of thumb if your television was purchase before 1998 it should have an analog only tuner.
If this is the case a digital converter box may be needed, if you get your TV signal from cable television or a satellite services they will automatically convert the signal for you so a box would not be required.
If you have more questions on the digital conversion has links and FAQ's on the subject at:
Go Ahead. Use Us.
May 19, 2008 | Televison & Video
Is Orion TV model 1929 ready for Feburary 17, 2009 Digtal conversion without the converter box ?
is the model number correct? Can't find the details of your television.
Does your tv use digital input? or analog if its analog then you need the box.
May 04, 2008 | Televison & Video
HITACHI ULTRASCAN 53FDX01B TV- do I need analog to digital conversion box ?
you do not have a digital tuner if that is what you mean. if you have a cable box you do not need to worry about this stuff but if you want to pick up over the air signals sometime next year you will need some type of hd to sd converter
Mar 19, 2008 | Televison & Video
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Analog or digital
no. all you will need is a digital cable box.all analog channels will not be broadcasted.if you have multiple tv's without a box,they would all need boxes.
Feb 02, 2008 | LG 15LW1R 15 in. LCD Television
Philips 60P8341 60" Rear Projection Television Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
