Question about Sentry Fireproof Safe
CSW3813 Sentry Safe won't open
Have a CSW3813 Sentry Safe. Put in code, key is unlocked, batteries are new. Handle is in down position door will not open. Handle won't even return to the horizontal position! Proceed unlock symbol visable when code entered. ??? Help...
  • 2 more comments
  • 1234bumper Jun 23, 2008
    Got the safe fresh out of the box. The door is locked in open position...new batteries and keys work. How do I get this to lock?
  • jojoyankees Sep 15, 2008
    Have the exact same problem.
  • Anonymous Oct 28, 2008
    yes, i do
  • Anonymous Apr 17, 2009
    I have the exact problem but my lever is in the horizontal position and can't turn it at all.
SOURCE: Sentry Model 1610 Won't Open
I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open?
Posted on Sep 27, 2008
SOURCE: new sentry csw3813 stuck open
Remove the screw from the backside of the door.
Posted on May 22, 2008
just keep trying and it will open. i had to try like 20 times the other day and it finally opened. good luck because these safe's are junk !
Posted on Nov 09, 2008
  • 416 Answers
SOURCE: Sentry Safe A3819
Go to
http://www.sentrysafe.com/customerCare/OwnersManuals.aspx
Find your model (pobably in safe for business)
And download the manual
Good Luck
Posted on Dec 23, 2008
do you have the manual i have the same problem but close and the manual is inside the safe is the original keycode but dont remember it
Posted on Jan 16, 2010
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
What do you do if the batteries are dead in my Sentry fire safe and can't put code in ?
a1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Security Safe with Electronic Lock...
I put in my combintaion, the batteries are good, the lock shows unlocked, but the handle will not move
I would say try replacing the battery holder. A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. New parts reclaimed from damaged freight returns. But only a small supply in stock.
Feb 26, 2012 | Sentry Safe Fire-Safe OA5865 Electronic...
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
New sentry csw3813 stuck open
May 18, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Feb 25, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,472 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
