Question about LG GSA-4160BI (GSA4160BK) DVD±RW Dual Layer Burner
Cd-writter problem when i want to write any thing on cd.The writer do all the steps and show successfully burnd,but after that when the cd was put to run then cd show blank.
  • JonPM May 11, 2010
    Make sure you don't have Test Mode on
  • Tim Babcock
    Tim Babcock May 11, 2010
    What program are you using to burn with?
My dvd drive is not ready to read the cd content.And also not writing the data to the cd.
my dvd model no:GSA-H20N.
S/N :608HEEP063428
ROM VER:1.01
Give me a solution.
Thank you.
Posted on Aug 23, 2008
    Sniper:
  • 65 Answers
First u buy a new lens cleaner for ur pc and run it on ur cd drive den ry to burn a new disk and see it burn or not if same prolem again comes then it is sure dat ur lense sensitivity gets low....
now it is not capable of writing ny thing only capable od read various cds......
if r havin more problems wid ur writer ask me for more solution..
Posted on Jun 20, 2008
Windows 7 does not see my dvd writter it sees a cd rom
Even though it's a DVD drive it just shows as a CD-Rom. When you check in system info it will appear correctly go to Start - Programs - Accessories - System Tools - System Information - Components - CD-ROM. You will see that as Media Type it will say DVD Writer there.
Sep 06, 2011 | Computers & Internet
I have lg dvd writer, model no. GSA-H55N .IT was running properly but today morning suddenly stopped.my project disc is inside the writer and it is not opening at all.also their is no dvd logo on my...
u observe ur dvd writter cleanily k there will be a small hole in it insert pin in it the dvd writter opens k :)
Hope this helps & please remember to rate my answer. Thanks
Feb 18, 2011 | LG Computers & Internet
I have supermulti dvd writter but they not read some times for same dvd disk
the dvd writer must be old or lens may have moister. So try to use lens cleaner or change the writer.
it may be beacuse of one more reasons DVD you are using must have lot of scratches.
Jan 02, 2011 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
I installed cdburnerxp but i cannot burn dvd in my cd burner, cannot detect the dvd inserted, alway said insert writable disk. my unit is Pentium 3, 600mhz, 512ram. it has a cd writter.
your saying that you have only cd writer. how can u write dvd in your system.
If you wrongly posted your problem then check and post clearly
Jun 24, 2010 | Computers & Internet
I purchased a Toshiba no cd writer program
Go to the Toshiba technical support website ( I just picked the one for Canada) and you may have to visit the equivalent site for your country or area. Anyway, enter the details of your laptop and click the [Go] button. You will be taken to a page where you click the button Product contents. On the page that will display, you will find everything that shipped with your laptop (hardware and software). If a disk writer software is included in the list and you did not get any, you can go back to the store where you bought it and ask for it.
Hope it helps.
Thank you for using FixYa.
Nov 23, 2009 | Toshiba Computers & Internet
Dvd writter
The reason your dvd writer is hanging is because there is a possible problem with the laser. Take a can of air and blow it into the drive to make sure there is no dust or dirt in there that could possibly be on the laser. After that then try different cd's and dvd's to see if the writer will read anything. If it still doesn't read and hangs on you, then the laser is bad and the drive would need to be replaced.
Mar 30, 2009 | Intel Motherboard
Dell XPS 200 CD/DVD reading problem?
the reade part of ur CD/DVD drive is damaged while the Burner is still ok .
1/use the cleaner disc.
2/replace the part.
3/replace the drive as a last solution.
plz do rate this post.
Dec 29, 2008 | Dell XPS 200 PC Desktop
Cd \cvd
try this website and you will find a reg editor which would take care of ur issue
www.kellys-korner-xp.com/xp_abc.htm
Oct 12, 2008 | LG GMA-4020B Super-Multi...
Installing
Hi tatieyanah...
For installing your DVD Writer follow these steps...
First , Place your DVD Writer in a Suitable position and fix it by the screws.
1. From your CPU SMPS(i.e, power box) you will have many set of wires coming with white plugs.Take one of those wires. Plug that into your writer's back side.REMEMBER you should plug it in the way that Yellow color wire should in the outer end and two black wires in the middle and red at the inner end.
2. If you dont find any wire in your CPU , use the one which is given to you ,which is a splitter in the DVD box.
3. Use the data cable given along with the DVD writer. Connect that Data cable( cable which is Wide and looks like stripes) from ur Mother board to the back side of the DVD writer. Take care that it is not connected upside down.
IF U NEED MORE INFO, REFER "http://www.computer-adviser.com/how-to-install-dvd-writer.html".
Post me your replies.....Bye ...take care...
Sep 17, 2008 | Computers & Internet
How to install a second DVD writer in an m8300f
for first dvd drive you have to put master jumper and for second you out slave then both drives work
Mar 21, 2008 | HP RT917UTABA - HP Promo dx2300 micro...
LG GSA-4160BI (GSA4160BK) DVD±RW Dual Layer Burner Logo
96 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
