Question about Xerox WorkCentre M20i All-In-One Laser Printer
FAX ERROR MESSAGE
I HAVE A XEROX M20I COPIER WHICH IS GIVING AN ERROR MESSAGE: OPEN HEAT ERROR" I TRIED TO FIX BY THE HELP THROUGH THE XEROX ON LINE HELP SITE BY UNPLUGGING AND RECONNECTING THE MACHINE BUT MESSAGE STILL PERSISTS.
ANY SUGGESTION BY THE EXPERTS REGARDING THIS PROBLEM?
THANKS!
  • 1 more comment
  • DERWESH Jun 19, 2008
    THANKS FOR YOUR HELP
  • rndasa Mar 05, 2009
    Open heat Error in Xerox M20 i model machine.uggections pls
  • Anonymous Mar 12, 2014
    xerox m20i dont get the paper to send a fax
  • Xerox Master
  • 2,794 Answers
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Posted on Jun 19, 2008
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
How do you fax papers to someone?
Download the user guide from here: http://www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
Open the table to contents and look for facsimile instructions, and then just follow them.
Mar 11, 2015 | Xerox WorkCentre M20i All-In-One Laser...
LSU error displayed on Xerox M20i
LSU stands for Laser Scanner Unit. It comes up only if you are trying to access scanner services like scanning a document, using fax or simple scanning.
If it's coming continuously you might need to check connectors within the scanner. Best way is to call a technician from Xerox or take it to their store.
Jun 21, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Have a Xerox M20i Copier/Scanner/Fax. Display indicates "Scanner Locked" Cannot make copies nor fax out. Please help
If you look under the scan assembly you will see a yellow or green tab which locks the scan head. Try locking and unlocking it a few times then on the final unlock reboot your printer.
Jan 18, 2011 | Xerox WorkCentre M20i All-In-One Laser...
The fax shows a messages saying "open heat error"
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
Jul 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Open Heat Error
it is a fuser related problem . check thermostat at fuser
Dec 10, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Hi. I have a Xerox M20i. The fax machine will ring, but then immediately hangs up. I have reset the memory and the DIMM chips as suggested by Xerox. The phone line works as the machine can fax out. Help...
Is your phone line in the " line" jack and not the ext jack?
If the line is digital it will do that.
If the phone line voltage is low, the line current low that will also cause the problem.
In your fax settings. Is ECM turned ON.
Is Junk Fax OFF.
Secure Fax OFF.
Delay Fax OFF.
If your phone line is weak, it will cause that problem.
Jul 13, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Cannot fax using my Workcentre M20i
The machine itself can not give that message. You have some tye of phone line issue.
Feb 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
377 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
