Question about Dell E153FP 15" LCD Monitor
Power green light flash
Hi i'm seeking help with my 3 year old dell E153FP color monitor, the problem is when i turn the cpu on the monitor does not start and show couple white stripe twitching up and down with the poer green light flushing.
it stays doing that until i tape the back of the monitor then the monitor come back to work with fisrt the genesis message.
  • mmgmalta12 Jun 25, 2008
    I have exactly the same problem. I do find though that as long as I keep the monitor off before turning on the computer it seems to turn on okay. Sometimes the flashing does happen so slap the back of the screen and it comes on. Annoying to say the least.
There are bads solder in power suplly board in 2 transformer used in flyback lamp circuit.
paul@ula.ve
Posted on Jul 02, 2008
  • 46 Answers
I suspect that you either have a loose connection or more likely bad solder on one of your boards. Check out this link for videos on opening the unit
http://www.lcdrepair.us/Installation.html
Iwould check all conections for a tight fit and closely examine the solder on the boards. You can use a pencil or something non conducting to push on individual parts after opening the back to isolate the problem..
Posted on Jun 21, 2008
The screen on my computer (dell E153FP 15" lcd) keeps going black everytime I turn it on. I can still see a very dark picture and the green light is still on but I can't see much. Usually I just turn it...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd. www.lcdrepair.us
May 20, 2010 | Dell E153FP 15" LCD Monitor
My monitor is flashing on and off. The screen is
Check for poor solder joint oat the AC inlet, common problem due to poor design to support the AC inlet connector, see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E153FP monitor
I have a Dell E173FP LCD, my monitor don't want to stop showing his Main menu , I had the problem since 3 months and didn't get a solution for it , some time it keeps showing the main Menu without stoping ,sometime not...crazy monitor.... But i have a friend that faced same prob and toldme to open the it and see inside it if there is a detached cable or anything...just don't know how to..please tell us a soultion.
Jul 06, 2008 | Dell E153FP 15" LCD Monitor
Dell touch screen monitor not lighting
Repairing the Dell E153FP with this complaint is not that hard but one that should be done by a qualified service technician or monitor repair specialist. Usually when you have this type of problem it is because either the inverter board, filter capacitors or the main board has one or more burnt components.
Any TV/LCD repair man can test this out for you if you don't mind paying them to do tht typical charges at our shop for such a diagnosis run around 35-50 dollars... this cost is usually included if you have them repair the item for you.
Jan 01, 2008 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
332 people viewed this question
Alun Cox
