Question about Western Digital (WDXUB1600BB) 160 GB Hard Drive
Over Current Notice
I plugged my external hard drive into my MacBookPro and a box popped up saying: "USB OVER CURRENT NOTICE A USB device is currently drawing too much power. The hub it is attached to will be deactivated" I take it out of that usb and put it in another one and it says the same thing.
I also have a PC and tried it on that and got the same response, so I think it is the external hard drive.
Also, I can plug the external hard drive into my mac, without turning the power button on and I get the same pop up. It's really odd.
Any help would be VERY appreciated!! :)
3 Suggested Answers
  • 83 Answers
SOURCE: USB over current notice
First of all, try it on a different machine - if it works OK on a desktop but not on a laptop, then you need to use an external 5V power supply.
You could also try and source a USB cable that has two USB plugs on it and connect the drive to two ports, but depending on the computer this may not help.
Posted on Jul 03, 2009
Geekman
  • 32281 Answers
SOURCE: mine keeps saying "USB Over
The power adapter could be faulty.
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Posted on Apr 14, 2011
Verbatim 1 tb frozen
the screeching noise worries me a bit
its sounds the video file being transfered was a bit to much for the usb capacity
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
even if you dont have any red or yellow marks you might have to
Click Start, then type device manager in the Search box then click Device Manager
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete restart your computer. Your USB controllers will automatically install
This method prevents your USB external drive from powering down
Disable USB selective suspend setting.
This method prevents your USB external drive from powering down.
Click the Start button type power plan in the Search box then click Choose a power plan.
Next to your currently selected plan click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings then expand USB selective suspend settings.
Click Plugged in then click the drop down menu and select disabled.
If youre using a laptop click Battery then click the drop down menu and select disabled.
Click Apply then click OK.
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 28, 2012 | Computers & Internet
I can't access wd 320gb element external hard drive
hope this helps
Jun 27, 2012 | Western Digital Elements 2 TB USB 2.0...
Hard drive is showing up as an composite device
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
hope this helps
Jun 23, 2012 | Western Digital My Passport Essential SE...
Mine keeps saying "USB Over
Apr 14, 2011 | Western Digital 250GB MyBook External USB...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
Jul 03, 2009 | Western Digital Passport WDXML800UE...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Western Digital (WDXUB1600BB) 160 GB Hard Drive Logo
137 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
