Question about Kenmore Oasis 27042 Top Load Washer
How to open the RPS motor?
I've the f51 code and what do I need to open the washer from the bottom? What type of screw driver ? I also have Ld code but the drain pipe is clean, sears tech thinks its the cpu is bad.
Thanks.
  • 413 Answers
Whirlpool has changed the RPS connector design, providing a more reliable connection. The control has also been updated for better sensing of the RPS sensor. Also, if you have experienced problems with certain wash loads getting tangled and knotted, there is also an update washplate intended to reduce this issue. You should contact Whirlpool for possible repair concessions related to these issues.
If you would like to get to the RPS sensor.. Here's how:
In some cases, the F51 code can be fixed by cleaning the RPS sensor connector. The RPS sensor is located on the motor armature underneath the machine.
1. Tilt the machine backwards, resting the console against the wall.
2. using a disposer tool or suitable hex wrench loosen the center stator screw completely (the screw is captive and will not fall out of hole).
3. The stator contains a series of strong magnets and will take some tugging and wiggling to pull off.
4. Remove the 4 bolts that secure the armature to the tub. CAREFUL this assembly is a little heavy, support well before removing last bolt.
5. The RPS sensor is attached to the armature. Remove and insert RPS connector (the one with 6 wires) 10 times to 'wipe' the contacts providing a cleaning action.
The 'Ld' issue may be related to debris caught in the drain pump impeller. To access, remove rear panel. The drain pump will be on the left side mounted to the tub. Remove hoses and inspect for debris in the pump impeller.
Hope this help..If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Posted on Jun 20, 2008
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
Nov 27, 2017 | Whirlpool Washing Machines
F51 Fault
e F51 code indicates a problem with the RPS (Rotational Speed Sensor) that monitors the motor speed. This issue has been identified as relating to the the connection system between the RPS and the controller.
Whirlpool has changed the RPS connector design, providing a more reliable connection and is available as a service kit. The control has also been updated for better sensing of the RPS. Also, if you have experienced problems with certain wash loads getting tangled and knotted, there is also an update washplate intended to reduce this issue. You should contact Whirlpool for possible repair concessions related to these issues.
If you would like to get to the RPS and try cleaning it.. Here's how:
In some cases, the F51 code can be fixed by cleaning the RPS connector. The RPS is located on the motor armature underneath the machine.
5. The RPS is attached to the armature. Remove and insert RPS connector (the one with 6 wires) 10 times to 'wipe' the contacts providing a cleaning action.
May 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis F51 code - already replaced RPS. Now what?
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Machine stops & flashes F 51
The F51 fault code on these types of washers indicates that the machine control board detects an RPS (Rotor Position Sensor) failure. This sensor is on the motor at the bottom of the washer.
Here is the troubleshooting for the F51 fault code:
  • Do not overload the washer. Overloading can cause this fault code.
  • Check underneath the washer for any clothes or toys that could be under the washer and obstructing the motor from turning freely. This can occur because there is not a cover on the bottom of the Washer.
  • Using too little water by choosing the wrong cycle for the type of load being washed can cause this fault code.
  • Make sure that your drain hose is properly installed per your installation instructions. Siphoning of fill water out of the washer can cause tub resistance and will result in this fault code.
  • Lift the lid and reach in and make sure that the basket turns freely. If not, you could have garments stuck between the two baskets or a problem with the basket hub. Any abnormal resistance to tub movement can cause this fault.
  • Unplug the washer. Make sure that both the Control Board Connectors P5 (Motor Wires, red, blue and yellow), and the P10 (RPM Sensor Wires, 7 brown wires) are securely plugged into the Control Board.
  • Remove the (P5) Motor Connector from the Control Board and take a resistance reading between the 3 combinations of motor wires (red/blue, red/yellow and blue/yellow). It should read around 32 ohms on the Motor Windings between any of the 3 pins on the harness. NOTE: If you do not get the proper resistance reading on the motor harness at the board, check the reading at the motor end. If you get a good reading replace the upper or Lower Harness whichever is defective. If the reading is still bad when checked directly off of the motor, then you will need to replace the motor. (See notes below for motor access.)
  • Unplug the P10 connector and take a resistance reading between the two outside pins (1 and 7). It should read between 600 and 21.6K ohms. *NOTE: (If it reads open you will need to pull the Rotor and Stator so you can check it right at the RPS Sensor. If it reads good at the sensor replace the Lower, or Upper Harness whichever is open).
  • To access the motor and RPS sensor, lean the washer back against the wall. Secure the washer with blocks if needed. Remove the rotor (1-bolt), and the stator (4-bolts). When you pull the rotor off, check to make sure that the thin plastic beads that run between each magnet on the rotor is intact and in place. This could cause an F51 code as it will no longer separate the poles of the magnet for the sensor to read them properly.
  • Check your wiring connections on the motor and the RPS sensor. Unplug and then plug the wiring harness connections back in on these components 5 or 6 times. This will normally scrape through any possible corrosion or deposits on the connections. Tug slightly on the connections when they are inserted for the final time to make sure that they are secure.
  • Reassemble the washer .
Hope this helps .
May 03, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis model 27082605 type 580 has f51 code what can i do
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F51 CODE. BOUGHT RPS KIT W10183157 TO FIX BUT FORGOT WHERE THE BOTTOM RED AND BLUE PLUG IN WIRES GO. I KNOW IT CAN ONLY PLUG INTO THE BOX ON EITHER SIDE BUT WHICH COLOR GOES TO WHICH BOX?
Mar 17, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore oasis he is flashing f51 and it wont drain. help!!!!
Hope this helps .
Mar 08, 2009 | Kenmore Elite 45986 Front Load Washer
Won't spin
The F51 error code flashes when there is a rotor position sensor (RPS) failure or lower harness problem.Here are some recommendations you can try to resolve this issue:
First disconnect the electrical power to the washer.
Make sure the basket turns freely. (By the way, make sure you are not overloading the washer. Make sure objects, and or clothing are not getting caught on the rotor underneath the washer jamming the rotor. Make sure you are not using too little water by using the wrong cycle for the type of load.)
Lean the washer back so that you can access the motor from the bottom then remove the rotor (1-bolt), and the stator (4-bolts). Make sure the stator and wiring harness have not been twisted causing the connector to twist at the RPS board creating a bad connection.
See image below for the RPS & harness location.
Unplug the RPS sensor connector and then plug back in 5-6 times to make sure if there is any conformal coating on the pins you cut through it and make good contact. Then tug back on the wires to make sure the connector bites onto the terminal and makes a good connection.
If you still have an F51 error code I would recommend calling a service technician to diagnose & repair.
Sep 02, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Show failure code F51
This has been a troublesome issue for Whirlpool and many of Whirlpools customers. The F51 code indicates a problem with the RPS (Rotational Speed Sensor) that monitors the motor speed. This issue has been identified as relating to the the connection system between the RPS and the controller.
Regards,
reg501
Jul 06, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Blinking F51
If you would like to get to the RPS.. Here's how:
If I can assist you further, please let me know
reg501
The FixYa Team
Feb 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore Oasis 27042 Top Load Washer Logo
170 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
