Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissel powersteamer clearview will not spray water
Chaged broken belt worked through one bucket of water changed water now will not spray water belts are still intack. tried priming, cant find anything clogged any suggestion
  • slmiller350 Apr 18, 2009
    I have a bissell powersteamer and it won't spray water from the uplostery or the floor cleaning part. but las night it had leaked water all over my kitchen floor. any suggestions?
  • Anonymous Mar 17, 2014
    the solution spray system is clogged
    President:
  • 1,673 Answers
Did the gasket on the bottom of the water tank come off and is either missing or sitting in the hole where the tank sits? It needs to be on the tank.
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Aug 10, 2008
Yes I had the same problem,you have to make sure the soap container has soap or I just use a mixture of soap and water if you want to call me I have more details 630-768-8981
Posted on Sep 04, 2009
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
ROLLER BRUSH NOT WORKING (BISSELL POWERSTEAMER PRO DELUXE )
The belt may be broken. Follow the link below to belt inspection video on www.bissell.com.
http://www.bissell.com/VideoRating.aspx?id=1555
Oct 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Changing belt on bissell powersteamer clearview 1692
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 11, 2010 | Bissell 1692 PowerSteamer Upright Vacuum
I have a Bissell PowerSteamer ClearView How do I
I removed the pump belt and the brush drive belt for replacement. I can see that the brush belt has little ridges to line up on the brush gear. Its the pump belt that I need help with. The flat belt goes over the shaft sticking out of the pump, but the other end appears to have a channel that the belt fits into and around. Only when I put it togeather that way the belt is off center, does the belt fit up over the rounded (pink) end before the channel or is it supposed to fit in the channel
Jan 05, 2010 | Bissell 8806 Powersteamer Upright Vacuum
Can't reassemble top of carpet cleaner
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Sep 20, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
2,459 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
