Question about Frigidaire Refrigerators
Freezer ffu20fc4cw0 no longer freezing, temp around 50 degrees, fan and compressor running.
Compressor is wacked.....
Posted on Aug 09, 2008
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
We have an Imperial Freezer that is cooling like a refrigerator, but is not freezing. We have this out in the garage.
Need to cool compressor, use a floor fan, compressor have a max temp @ 160 degrees, and will shut down if they get hot. This will cause it to run in this manner. The fan is a short term solution, need more air flow around freezer to correct problem. Good Luck
Jul 11, 2011 | Refrigerators
Refrigerator temp stay around 50 degree
Hello, Thank You for using FixYa. I will be helping you today.Try cleaning under the front and rear also make sure the fan in back runs when the compressor runs.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Refrigerators
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Freezer temp risen to over 50 degrees. Refrigerator temp also risen to over 50 degrees. Water puddle on floor.
Check the fan in freezer is it running? Check the fan by the compressor is it running? Is the compressor actually running? Be careful can be extremely hot.
Nov 13, 2009 | Refrigerators
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
Freezer Not Freezing
check compressor is turned on. if compressor is going, you either have a system or compressor fault and this is not diy if compressor not going, possibly a thermostat fault. in this case put on fast freeze to confirm
Jun 15, 2007 | True 23 cu. ft. / 651 liter Commercial...
Refrigerators Logo
138 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
