Question about KLH R5100 Receiver
Trouble i turn on the receiver ,but speaker doesn't turn on
  • KLH Master
  • 1,550 Answers
The audio amplifier IC is in bad conditions and need to replacement.
Posted on Jun 19, 2008
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
Loud speaker option doesn't appear when call receive
When you receive a call then press on/off key for some time then you will notice loud speaker and hold option there .
thank you
Jan 24, 2013 | Samsung Corby 2 GT S3850
Yamaha RA-V1200 wont turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .if it stays on whit no wires attached than u have short connection at speaker wires . if doesn`t come on then try to fasten screws at back of the unit , may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happened to me on RX-V592
Jan 16, 2013 | Yamaha RX-V1200 Receiver
Bought the stereo 6 months ago, now the speakers won't work!!!! Please help!
Hi, when a speaker does not work, you might need to do some troubleshooting tips to know exactly where the problem is .
First you will need to test the speaker cone if it's working properly by using an AA battery and two wires to make sure the cone is working..
Connect one of the wires to the Positive side of the speaker, and the other on the Negative side, And after that use the battery to hear if the speaker cone will make a click sound.
If it doesn't make a click, that means the speaker cone is Bad, you will need to replace the speaker cone,
But if there is click from the speaker cone, that means the speaker is Ok, and you might need to trouble shoot your stereo to be sure if the sound IC chip is Ok in the stereo..
Hope it helped..
Aug 10, 2011 | Audio Players & Recorders
I have an Onkyo AV Receiver HT-R500 and when I turn it on, it turns on and in less than one second it turns back to standby. What could be wrong?.
Try disconnecting all the speakers and see if it does the same thing. If it doesn't, connect speakers again one at a time to find out which one of them is doing it. Make sure the speakers rating match the output of the amp.
Jun 16, 2011 | Onkyo HTR500 Receiver
I have a set of 5 mirage nanosat speakers. Two of them have no sound. The other 3 are fine. Moved from Condo to home. As far as I know they were working in the condo. Any Ideas?
First thing to do is diagnose where problem lies - speakers or receiver or maybe wires. Take a working speaker and hook it up to the same wire that a non-working speaker is currently connected to. If the speaker now works, the problem is in the speaker, if it doesn;t work the problem is either the wire itself or the receiver. If possibly the receiver, check speaker set up menu in the receiver to see that all the channels are turned on. Have you talked to the dealer you bought it from for help? I'd start there after diagnosing problem as described above.
Jan 19, 2011 | Mirage NANOSAT Speaker
Turn off audio to speaker A while keeping B on.
If youre running 5.1 Home theater in one room you wont be able to just switch to the other room with 2 speakers without changing the receiver settings to "Stereo" mode
Apr 10, 2009 | Audio Players & Recorders
Distortion using rear speaker interfaces.
yea get new speackers or u have a very low quality wire also can bet out of eq
Apr 02, 2009 | Pioneer VSX-1018AH-K Receiver
Ccr1cd keeps turning off my yamaha receiver rx-v480 keeps turning off when i turn it on
check your speakers cables, connections. check for possible cable short. If seem ok, remove all speakers, turn the unit on and see if still turning off. if it does then you have a trouble in your power amplifier, defective output sectiuon. could be your power and driver transistors. possible dirty or corroded system control board. try cleaning.
Dec 24, 2008 | Yamaha RX-V463 Receiver
Short in speakercable
Check the speaker cable connections between the Plasma Display and the speakers. replace it if needed. it will work.
Oct 11, 2005 | Pioneer PureVision Pro-1120HD 50 in. HDTV...
KLH R5100 Receiver Logo
46 people viewed this question
Top KLH Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
