Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
The headphone interior cable does not work.
I changed the headphones of my Zune numerous of times. Untill I finally figured out that the problem wasn't the headphones but it was the inside part that allows the music to flow through the headphone.
  • KathyyWatty Jun 22, 2008
    Thank you so much for your solution Aaron. I really appreaciate it and it really helped me.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey Kathyywatty,
The problem you're encountering may not necessarily be a loose internal connection, and may instead be a defective headphone jack. In cases when headphones are unable to make a secure connection, users may only experience sound coming from one of their headphone's speakers, a static-filled signal or no sound at all.
While there may be some third-party parts suppliers that carry replacement components you can install on your own, I'd strongly suggest contacting either the toll-free Zune support hotline or your local repair facility for further assistance. Any repairs that are not performed by a factory-authorized technician may void any warranty coverage you still have on your Zune.
If you're not sure how to contact Microsoft, you should be able to reach their technical support by calling 1-877-GET-ZUNE (877-438-3269). Additionally, if you're not quite sure where your local repair facility is, you may always bring your product into the Geek Squad® counter at your local Best Buy™ store for service and support.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 20, 2008
Everytime m headphones move my zune acts like they fell out and stops playing but they didnt so i bought new headphones and found out it was the zune that was acting up........i was wondering if it cant be...
Sounds like the headphone jack has broken solder connections to the circuit board. Mine MP3 player did too.
Fix it with a REALLY small-tipped soldering iron, re-solder the jack connections... not real easy.
Or return/exchange it.
Jul 18, 2010 | Microsoft Zune JS8-00001 Digital Media...
I have a zune 120 mb. It shows it is playing a
First off. i think you mean 120gb.
Secondly, Here are just a few different suggestions.
1) Make sure its not muted on your zune
2) Some headphones have a volume switch on them so if yours have that switch, turn them up.
3) Try a different pair of headphones.
Nov 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
Jan 26, 2009 | Sennheiser RS 120 Consumer Headphones
The receiver for my headphones in my 8GB Zune doesn't work
wo, wo ,.wo what do you mean the receiver? the headphone plug in? if thats the case then it better be under warranty because ms will charge about 160 so ive been told. It will have to be repaired by MS
Jan 06, 2009 | Microsoft Zune JS8-00001 Digital Media...
Can i hook a surround sound to my zune
It is usually as simple as getting a 3.5mm stereo headphone jack to RCA adapter, like this one:
http://www.radioshack.com/product/index.jsp?productId=3359117 (this will work just fine, even though it says 'ipod')
Or they have "Zune Ready" adapter kits, like this one:
http://www.radioshack.com/product/index.jsp?productId=3004031
Once you have the cable, you stick the headphone plug (3.5 mm stereo mini-phono) into the headphone jack on your Zune, then you insert the red and white RCA jacks into an open input on your surround receiver... most have an auxilliary input jack set on the front of the unit. All you need to do at this point is select the "aux input" for the source on the surround receiver, start your Zune, and make sure the volume on the Zune is somewhere in the 50 - 75% range, and you should be good to go.
Dec 08, 2008 | JVC THD-50 System
Zune
You mean no sound comes out ?
First try some other headphones
and make sure your sound is up and mute is off.
if that doesnt work, see if there is something stuck in it.
if that didn't work its probabaly an internal problem and then your only options would be to get it serviced or bring it back.[hopefully you still have warranty]
Good luck.
May 08, 2008 | Microsoft Zune JS8-00001 Digital Media...
No right ear audio
This is caused by the output jack on your zune, what happened was when your headphones were plugged in they got bent or twisted and it moved half of the holder away so it is not touching the cable when it is plugged in, you will probably have to send your Zune into microsoft to have this fixed.
Jan 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Mic is not recognized
Just had the same problem occur on a laptop with same mic. Did the exact same thing yours did, I turned the mic boost on and ran the hardware test three or four times and it finally picked it up. Hope this helps.
Oct 21, 2007 | GE (98980) Headset
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
124 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
