Question about Lexmark Z615 InkJet Printer
Hi, I downloaded the softwARE but cant
Figure out how to open the printer to put in the cartriges and do a test pattern
  • poshweb Jun 19, 2008
    hahaha mine doesnt have a door that opens it is a z615 and nothing seems to open
  • Lexmark Master
  • 2,794 Answers
If you lift the door open the cartridges should come out to the center of the machine.
To print a test pattern, go to the control panel, select you printer with the mouse, press the right mouse button and select properties.
Select printing preference and look for a service tab.
That should contain the test pattern.
Posted on Jun 19, 2008
I had refilled my canon 831 color cartrige but it is not working and it is also blocked non of the color is printed in pattern check. how can i resolve cartrige blocking problem????????//
Open the printer and remove the catridge
Use a tissue paper and clean the nozzle where the ink comes out from
After you have cleaned the nozzle, press the catridge on the tissue and see if the color stains the tissue
If it does, you put the catridge back into the printer and then try to print.
Jul 06, 2011 | Computers & Internet
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
My printer will not print in black. I put in a new black cartrige after the old one did the same thing so I know its not the cartrige itself. I used the instructions on the printer for it to clean the...
Maybe there is fault in the software and will need a re installation. so remove your printer from the PC and un-install the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer HP Officejet J4580 All in one, does not print, It reports "Entering sleep mode". Put new ink cartriges in, paper not jammed and no lights flashing and I printed a test page on the printer to...
Hi.
Try the following in order:
Disconnect printer power cord.
Turn off computer.
Disconnect computer power cord. (if laptop also remove battery)
Restart first computer than printer.
(this may look stupid, but it drains power that can jam USB ports and cause malfunction).
Clean the metal plate contacts in the ink carriage using cotton and isopropyl alcohol or cleaning solution.
Try turning off printer and performing a new cartridge installation. Use the HP software cartridge replacement procedure, do not simply swap cartridges.
Disconnect printer USB, reinstall printer software, connect printer back when prompted by setup wizard. Updated software for this model available at Software & Driver Downloads.
If you have spare cartridges, test them, the problem may be caused by a defective cartridge chip. Non original or refurbished cartridges commonly cause similar problems.
Sep 14, 2010 | HP Office Equipment & Supplies
Hi,I've got a ip1800 printer that will not work ovbiously was working just fine until I try to replace the ink cartrige. Please help. Leo
try to reset your ink counter.. open control panel->click printer and faxes->right click your printer and click on properties (open printer properties)->click maintenance tab and click ink counter reset and check the ink box you alredy replaced and reset then.
2. if still not work check your print pattern in maintenance tab too and print..
3. cleaning your printer in maintenance properties and print check pattern again...
i hope this solve your problem.. good luck
Sep 15, 2009 | Office Equipment & Supplies
Ink Levelos are blank after replacing black cartrige and still will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jul 01, 2009 | HP DeskJet 5150 InkJet Printer
My Epson stylus C86 will not print even though I have put 4 new cartriges in and cleaned the heads
Check.......removable tabs removed, cartridges installed [they Click when pushed down]. Did you get a Clear test pattern? If all the above have been done and you still have a problem, it's time to call Epson tech support
Jun 29, 2009 | Epson Stylus C86 InkJet Printer
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
Lexmark Z615 InkJet Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
