My electric shower can take up to 20mins to come on any suggestions?
  • Anonymous Apr 27, 2009
    may shower nead sarvis
Sometimes, depending on where you live. There may be sediment build up inside the heating coil. This happens if you have had the unit for a long time or in heavy sedament areas.
The solution is to disassemble it use a declogger solution, then reassemble it. Make sure you turn off the electricity
Posted on Jun 24, 2008
  • 828 Answers
Some water heaters are controlled by a timing device that does not energize the water heater for a time period after power is applied to the circuit.
Posted on Jun 20, 2008
Have a 8.5 new team electric shower low pressure light on & no water coming out
Jan 14, 2015 | Home
Triton cara shower has power and water to it but nothing comes out
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Get a shock from the tap while showering
I assume by main power feed your talking about the breaker box? If so make sure the breaker box is actually grounded. Also check inside the heater and make sure the ground wire in there is connected and has a solid connection.
Feb 17, 2014 | Rinnai Water Heaters
Have a mira sports shower. when i turn on at isolated switch light comes on but when i turn on shower light goes out. no sound of water coming to unit or electrical sound in unit.
Have you checked if when turning on the shower water the electrical trip switch turns off at the fuse board. If the shower does keep tripping the RCD then the shower is the problem.
Apr 01, 2011 | Home
The shower keeps tripping the electric
Sorry to read about your problem, I hope this helps you out.
you must have a leak, in the shower...I suggest you stop taking showers, and call a plumber to find the leak
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Oct 08, 2008 | Home
Fitting Electrical Shower -electrician will do final connection at consumer unit
Thought the service was free
Silly me, only found out it wasnot after I had typed the questioin and thought it would then be aired on the forum anyway
Thanks anyway,
Jul 31, 2008 | Kitchen Appliances - Others
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
