Question about Fujitsu Siemens Computers & Internet
I am trying to find a spare battery for my laptop EM V 5535
    Master:
  • 848 Answers
Locating the motherboard battery for Acer Aspire 5535
i think, it is under the fan, but it is glued in something ? maybe you can remove the keyboard, and clip of that blue/white cable on the left to flash the bios ???
Jul 21, 2012 | Acer Aspire 5535-5050 Notebook
Power light on computer and nothing else
Remove main battery to see if it will start up, no change! pull the ram memory out one at a time and try again, if still nothing! the DC jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop must be dismantled to assess the situation.
May 08, 2012 | Acer Aspire 5535-5050 Notebook
Acer aspire 5535 is dead no lights no power nothing
Try removing the battery and running just on mains power. If that doesn't work, it sounds like the motherboard has failed and will need replacing.
Mar 26, 2012 | Acer Aspire 5535-5050 Notebook
Hi!! I have Notebook Acer Aspire 5535 maybe 3 week now that it have notification massage consider replacing battery can anyone help me.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 29, 2010 | Acer Aspire 5535-5050 Notebook
Laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Jul 16, 2010 | Acer Aspire 5535-5050 Notebook
My laptop runs very slow on Mains power, but runs fine and fast on battery???? (Acer Aspire 5535) This only started approx 2 months ago. Tried all the usual clean ups, registry ect, but didd not help. Is...
Have you checked the power plan settings? This is usually accessed by a battery/plug icon on bottom right of the screeen, if not then on the control panel.
right click on the icon and select power options. This gives you options for balanced, high performance or power saver. Clicling on change settings allows you to set CPU performance for mains and battery for each power setting.
for instance I usually use the balanced setting with a fast CPU when using mains and slower (to conserve battery power ) on battery.
Feb 26, 2010 | Acer Aspire 5535-5050 Notebook
My aspire 5535 crystal eye webcam shows me upside
Hi, Try Reinstalling your Drivers for your cam.
Thanks
Feb 07, 2010 | Acer Aspire 5535-5050 Notebook
Hello, acer 5535 Laptop, internal bluetooth problem
your laptop uses a foxconn bluetooth set. Make sure you have the proper driver for this device. Go to Acer support and make sure the driver is up to date. May look something like this:
Fox_brm_2.0 F/W 300
I believe this laptop is still using the bluetooth standard 1.1, so there shouldn't be an issue with finding another bluetooth device. Just make sure that the other devices are in discovery mode or they won't be seen regardless. Discover mode should be able to be accessed through the options tab under bluetooth. Good luck, ParrotHead PC Repair
Sep 06, 2009 | Acer Aspire 5535-5050 Notebook
Computers & Internet Logo
99 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
