Question about SanDisk Sansa e250 MP3 Player
My 4gb says that i have used 2 gb but there is nothing on it. i formated already and their are no pics or vids either.
  • 8,596 Answers
Switch from msc or mtp mode to auto, and see if the files show up again.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 25, 2008
What video file format does my Eclipse 180g2 4gb mp3 music/vid player read?
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Dec 24, 2012 | Eclipse 180g2 4gb mp3 music/vid
Memory card requires formatting
1. back up all your pics and vids (save them to your computer)
2. A delete (format) all your pics and vids from your memory card through your camera delete button (if it has one)
2. B delete all your pics through your camera menu if 2. A don't work
2. C if you can't delete everything through your camera use your computer to delete everything from your memory card
hope it helps
Aug 07, 2011 | Kodak EasyShare C315 Digital Camera
I have a vaio sony 4 GB flash disk when i try to put pics and song and videos in it it works for some min and in the same computer but when i try to put it to another pc after playing the video it says can...
Hello
theres a few things you can do, when you do format your memory stick make sure you format it to the default settings.
Also make sure everytime you put files onto your memory stick that you remove the memory stick safely you can do this by right clicking the memory stick and pressing eject.
However the problem could be that your memory stick is corrupt.
Jul 13, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
DigiGr8 DV182 - I have inserted batteries and a 4GB SDcard but when I switch it on, the screen just says "Welcome" and does nothing else. Without the SD card it looks like to will work but says "No Card"...
The problem is with the 4 GB smart card you are using. You need to exchange it for a 2 GB smart card and that is all this little camcorder can handle. Hope this helps.
Sep 14, 2010 | Cameras
CAN NOT BE FORMATED
Hi
try to format your kingston with
Following tool.
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Feb 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't save pics/vids to micro SD card
First apply code *#7370# or *#7780# Format your 2 GB micro SD ohter wise contact mob-ph repairing centre.
Aug 25, 2009 | Nokia 6133 Cellular Phone
I pushed format on my camera just to see what it does. and all my pics and vids are lost! i kept reformatting and tuk 2 more pics but didnt save them. i am sooo scared they mite b lost. i just turned 14...
Format is used to clean everything off your memory card or memory device. Do not format until you have downloaded your pics.
I seems they are lost.
Jun 17, 2009 | Samsung L200 Digital Camera
Cannot format PNY 4gb microsd card
I could help if you provide some more information about the error message or something.
The most common cause is something might have corrupted the video card and its no longer usable
May 30, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Formatting
Hi Dear, Same Problem Happened With Me When I Inserted 4GB M-Card In Phone, Later On It Failed To Format And Whn I Use That Card In My Card Reader On PC It Waz Showing 1.8 GB,
I Guess Yu 've To Use 'HP Formatting Tool' To Fix It Up,
Before Downloading, Wanna Let Yu Know What Happened To My Other M-Card Whn I Used It...
I Had 2GB M-Card When I Formatted It On 'HP Formatting Tool'
Later On It Waz Showing 4GB, I GuesS Itz Only Coz That Version Of HP Formatting Tool Supports Only 4GB M-Card Coz It Waz Already Mentioned On That Tool On The Dialogue Box,
One More Thing That Yur Phone Might Not Supports 4GB M-Card And Made This Mess,
Hope This Helps
Best Of Luck Dear...
Mar 31, 2009 | Electronics - Others
SanDisk Sansa e250 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
