I have 2 workgroup/LAN's that I'd like to connect using a VPN. I have successfully configured the routers so that I can Ping from the remote location to the main location. I can also ping the other way.
However, I Remote Desktop doesn't work and I don't know how to transfer files from network to network ... which is the real reason I'm going through this whole thing. I do not run file servers ... rather both are just peer-to-peer networks.
Help.
N.
Comments:
Jun 21, 2008
- each LAN is at a different location. i'd like to connect them together so that we can file share and perhaps duplicate the functions of 'gotomypc'
does that answer your question?
N.
Jun 21, 2008
- i have one network 10.1.1.x a second network 11.1.1.x they both share files within their own location, in a peer2peer manner, no files servers. each network has a router (2 exact same models for each network) that access the internet. i have configured the routers' VPN settings to talk to each other over the INternet. I can PING network 10 from network 11, and vica versa. However I can not perform any other funtion ... remote desktop, file sharing..
thanks,
N.
Jun 21, 2008
- the ISP isn't blocking ... what should the WIndows settings be? What ports shouldn't be blocked?
Yes it helps to know that, thanks. If you are using similar flavors of "Windows" at both ends and the VPN is setup correctly then file-sharing should be relatively easy to accomplish.
Do you already share files on each discrete network locally?
Comments:
Jun 21, 2008
- Which ports is your hardware using for the VPN and have you checked / or can you check that your ISP is not blocking VPN traffic?
Jun 22, 2008
- Let's check some basics, I think it'll be more useful at the moment. Do you have these or similar settings on your VPN routers?
Windows Networking (NetBIOS over TCP/IP) Allow NetBIOS Traffic Through All IPSec Tunnels
Secondly have you got a network sniffer program available to you?
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
I have a netgear RP614 my nat is to strict to connect to some friends in online games.How do I open...
(More)
I have a netgear RP614 my nat is to strict to connect to some friends in online games.How do I open this on this model
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the...
(More)
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the internet at the same time. It also drops when I get an incoming message on my blackberry.
we have lost connection from our lap top and the wireless light on the router is out. i hope you can...
(More)
we have lost connection from our lap top and the wireless light on the router is out. i hope you can help. many thanks
