Question about IOGear MiniView GCS62 2-port KVM Switch
KVM switch I hooked up the switch according to the instructions. When I click on the scroll lock, what I nget is a black screen telling me there is no signal. I swithched the cables around, no good.
  • Aubreynna May 11, 2010
    Do you have a display when the VGA monitor is directly connected to the non-working CPU (when you got no signal)? How many video cards do you have on the non-working CPU?
    Problem Solver:
  • 6 Answers
If you tried to switch the two cables and the problem remains on the 1st cable then definitely the port 1 is already defective.
Posted on May 19, 2009
I've got an "Integrated KVM
Apparently there is no online manual for this product..
However.. To switch from one pc to other, you need only press the Scroll Lock button 2 times then number 1 or 2 .
Hook up should be easy. Your KB &mouse & video plug into the little blue block and the wires from the block plug into the pcs like normal, KB mouse and video. That's it.
Switch between pcs with the button on the block or the KB code.. Scroll buttontwice then 1 or 2.
Dec 12, 2010 | Linksys Computers & Internet
I have this switch hooked up to my PC and Xbox 360.. everything works correctly, however when this was given to me.. it had no instructions of sorts.. how do I switch the inputs?
Press the Scroll Lock key twice to toggle between the two machines. (Either the right or left scroll lock key will work) .
There is also an auto-scan mode which is accessed by pressing the Left Shift key and then the Right Shift key within about 0.5 seconds. This shows the screen for each machine alternating at a set rate until you press the Spacebar. The active screen when the spacebar is pressed becomes the active manual.
The manual is available at: http://www.iogear.com/support/dm/manual/GCS62#display .
I hope this helps.
Sep 19, 2010 | IOGear MiniView GCS62 2-port KVM Switch
KVM Switch Key Strocks?
Check here...
http://www.inlandus.com/inlandfaq/docs/instructions/08214_PS2_KVM_Quick_Setup_Guide.pdf
Apr 12, 2010 | Inland 08216 2-port KVM Switch
Belkin Flip PS/2 - KVM switch - 2 ports how do i switch from pc to pc on key board
The instruction below the link is for a 2 port version KVM, and may not apply to your particular model. You can look your model up here:
http://en-us-support.belkin.com/app/product/list/q/kvm/session/L3NpZC9BSk5yVUZKag%3D%3D
You can switch directly to any port by entering the Switch port number you wish
to use. For example, if you press “SCROLL LOCK”, “SCROLL LOCK”, “2”, the
computer on port 2 will be selected.
AutoScan Mode
In AutoScan mode, the Switch remains on one port for eight seconds before
switching to the next. This time interval cannot be changed.
To enable AutoScan mode, press “SCROLL LOCK”, “SCROLL LOCK”, “S”.
Oct 05, 2009 | Belkin Computers & Internet
Freedom 9 kvm switch how do you switch from one pc to the other?
Press the Scroll Lock twice fast and then eith the up or down arrow.
Apr 06, 2009 | Freedom9 freeView 2UA (KVM02U) 2-port KVM...
Keyboard Sequence for Compaq 4-Port KVM Switch (Series 4115)
Mine uses the "Print Screen" for the menu & "Print Screen" + 1, 2, 3, or 4 for direct access.
Feb 13, 2009 | Compaq (147092-001) 4-port KVM Switch
About the belkin 2 port kvm switch
i already have one computer hooked up to a beklin. can i hook up another
Apr 09, 2008 | Belkin F1DK102P 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Hot key
for mine it's:
tap scroll lock twice then press 1 or 2
Sep 26, 2007 | Belkin F1DK102P 2-port KVM Switch
IOGear MiniView GCS62 2-port KVM Switch Logo
240 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
