Sony DVD-RW DW-D56A drive playing up
I am currently running both Windows XP and Vista on my laptop and find it quite strange that I have the following problems on BOTH operating systems:
1) Inserting a blank DVD makes my drive show up as "CD drive".
2) Inserting a video DVD makes things crash. The drive doesn't sound like it will "spin up". However, going into VLC media player and loading the disc allows me to play it.
3) Data discs won't load. I again get the failure of the drive to "spin up", and I have to eject it to stop things from freezing.
4) In safe mode for Vista and XP, the drive will detect all discs fine. I can open them up and explore them...EXCEPT DVD's...they still won't work properly unless played in VLC player.
I would be very grateful to any sort of help on this because it has me baffled! I thought it was a hardware issue to begin with...but after seeing that I can get various discs to work, I am led to believe it is a software issue.
Thanks in advance.
I am not posting a solution, but may be the same problem.
I have dell inspiron 510m with DVD - RW sony A 56
It had burnt one DVD till now, but it can NOT burn any more DVDs.
I have tried burning using windows XP-SP2, Nero 6, Nero 8, burn my files 3.01 BUT no use. The only thing I got is different error messages.
I changed many types of DVD-Rom, from sony, benq..trying to rule out the storge media itself as source of error, but again no use.
Astonishingly, it works a CD-ROM Burner very well.
Any suggestions?
Posted on Aug 06, 2008
Sony dvd+rw dw d56a plays cd's. doesn't see dvd's at all. I hear the disc spinning. Doesn't see it. control panel - double clicked on drive - nothing
It is possible that there could be some garbage in the processor do to a small power surge and if you unplug the unit from the wall for 40Min., it will reset back to normal.
Mar 09, 2011 | Sony (DW-D56A-10/20) (DWD56A1020) DVD...
I have a Sony Vaio VGC-V517G but the CD/DVD opticle driver does not work Sony sales it for $200. Does some one know where I can get it for cheaper?
A Driver is a small piece of software, that allows the Operating System to 'communicate' with a device.
Windows XP is an example of an Operating System. (O/S)
A typical device?
An Optical drive, (CD/DVD), Mouse, Keyboard, and Graphics card, are a few examples.
This is Sony eSupport, and the Drivers download page, for the Sony Vaio VGC-V517G Notebook PC,
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGC-V517G&region_id=1
Go down to the third file listing -
CD/DVD Drives - 2file(s)
Left-click on the + sign before,
CD/DVD Drives -2file(s)
If your optical drive is the Sony DW-D56A, download the second file listed,
(Sony DW-D56A DVD -+RW Optical Drive Firmware Update Utility)
I also suggest you download the first file listed also.
Download both files. Open one at a time. Open one file, then install the file. Then open the other file, install it.
Go to the right, and left-click on the icon that looks like a blue World, with a green down arrow under it.
On the next page go to the right, and left-click on that same icon again. (Under the - Download Now - heading)
Should you need additional info, or help with the above, come back, and state so in a comment.
Or ,have I understood your problem wrongly? If so state it in a comment. Allow me the chance to give you the right information, before you rate the solution.
joecoolvette
Jan 02, 2010 | Sony VAIO VGC-V517G PC Desktop
DVD drive wont run DVds or CDs
I have a dell desktop computer Dimension 9150.
My DVD drive is not working. I can run DVds.
Can you help?
Apr 02, 2009 | Dell DVD-rom DVD Drive
Laptop Disk Drive want reject.
If you mean the CD or DVD drive,,,then you can take a paper clip and bend it straight,,then put the paper clip into the tiny hole in the front of the CD tray and gently push,,,this will open the tray enough for you to grip it by hand and pull it out the rest of the way.
Jan 19, 2009 | Sony (DW-D56A-10/20) (DWD56A1020) DVD...
Sony dvd rw dw-g120a
I cannot burn my home movies to my dvd drive, my dvd drive is called SONY DVD RW-G120A, it says this device is disabled Code 22, Please help me fix this problems. Thank you
Oct 15, 2008 | Sony DW-G120A DVD RW Dual Layer Burner
Reads and writes cds,reads dvds but does not burn dvds,
This drive is normally supplied with a couple of Dells.
(because of compatibility) Inspiron 700m,710m
If you have another machine for testing?
check the disk for contents to see if the data burn happened,
this will explain a few things in your processes.
Uninstall/Reinstall the drive and reboot then try again.
Have you tried a full system reinstall yet?
Did it fix your problem?Please let me know thanks
Jul 15, 2008 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
DVD Drive problem
There maybe a problem with a ribbon like cable that connects your drive to the mainboard. In order to be sure if there is a hardware problem, try to boot your laptop using a bootable cd. If this works and you can read files from the cd then it maybe a windows instalation or driver problem. My best guess is however a hardware problem related to that specific cable or connector. You should try to check these if possible. If your laptop is still in warranty send it to a service center for in-warranty repairs. Otherwise I may help you on how to dissasemble it or how to check that connector.
Hope it helps,
Bogdan
Feb 09, 2008 | Dell Inspiron 6400 Notebook
DVD reading problem
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Goodluck!
Jan 18, 2007 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
