Question about Acer Aspire 5315 Notebook
No juice computer will not turn on it started with the battery low light blinking and then it would not charge the battery up and all of a sudden you cant even power-up with the power cord even though the power cord has a green light. computer is very unresponsive at this time no beeps chirps or whines. please assist
    Genius:
  • 2,028 Answers
Sounds like a battery issue. Try powering up without the battery, just AC. If it powers properly, then the battery needs replaced. If it doesn't then it may be the power supply malfunctioning, or the motherboard.
Posted on Jun 19, 2008
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
I'm having a problem with my laptop AsusPro555. the problems is with the when i turn on the laptop it starts up and then turns off again... green light turns on but suddenly cuts off again.. i Don't know...
Let's start with the basics:
A. Is your battery charged?
B. Is it holding a charge?
C. Your laptop could be getting too much or not enough juice (power)
Oct 21, 2013 | ASUS Computers & Internet
Engine turns off
name the switch.
be exact.
but clean the battery lugs first.
Oct 16, 2013 | 1999 Ford F150 Regular Cab
WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
It is an electrical problem with the starter or maybe the cylinoid. Lights work fine so there is enough charge in the battery. Engine will not turn over or even crank, but the lights work fine. What...
actually the battery can have a dead cell and the lights will work ok and not even blink or dim when attempting to start, but not enough juice to turn over an engine. does it click when you try to start? could be a bad connection (cable, cable ends, solenoid, or even starter armature problem). your local auto parts store can check the battery and starter off the car if you carry it to them - free of charge.
Sep 10, 2010 | Chevrolet 1500 Cars & Trucks
Nokia N900 not turning on or charging
not turning on. red notification light showing
May 14, 2010 | Nokia N900 Smartphone
Car will not start, but the battery is fine, lights work
The lights will work with a low charged battery but not hve anough juice to turn the engine over, try and jump it. Let me know if this was the problem.
Feb 24, 2010 | 1996 Mercury Mystique
My gauges work but it wont turn over i dont hear any noise from the starter
Three possibilities I think:
First is weak battery. There may be enough juice to light the gauges but it takes power to turn an engine.
Second, bad solenoid. The solenoid is a relay which closes the high current circuit that delivers the cranking power to the starter motor. If you hear clicking in the engine compartment (not the starter) when you turn the ignition switch on it is probably the solenoid engaging and disengaging. However if the battery is weak it won't turn the starter motor. If the solenoid is clicking look at the battery first. The solenoid could be bad but the clicking indicates it's trying to work and there just may not be enough juice to turn over the engine.
Third possibility is the starter motor itself is dead. You have to answer some questions for yourself. Is this an old,neglected car or one that has been taken care of? I would be looking at battery. Can you jump start it? If yes then weak battery is the likely problem. If the car and battery are relatively new and in good condition you should suspect the charging system, that is, the alternator. Did this happen all of a sudden on a car that was running fine recently or has the car been sitting idle for weeks/months.Eliminate the easy stuff.
Clean battery terminals?
Good battery connections and ground?
Try jump start - if yes then follow up battery/charging system. If no start then try to hear for solenoid clicking. If jump start does nothing -figure the solenoid first. If it sounds like solenoid is kicking in but engine does not turn then the starter is looking a little guilty. Jump starting will answer a lot of questions. If the car is really dead then the car that is jumping may have to be connected and revved up a couple minutes to juice up the dead battery enough to turn the starter over. If it turns over a little during the jump start but just barely then you should figure your battery is bad.
Sep 04, 2009 | 1992 Chevrolet S-10
Blinking light on center of the dashboard on Hyundai Sonata
That is your security light, It tells you the security system is active.
Apr 01, 2009 | 2009 Hyundai Sonata
Acer Aspire 5315 Notebook Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
