Question about De Dietrich 23 in. DVF110J Built-in Dishwasher
De Dietrich DWH - DVH610JU1
The dishwasher stops after a few minutes before the water comes in and the end blue light starts flashing rapidly.
I tried to reset the programme by pressing 'start' for more than 3 seconds. The same thing happens again.
  • paul1976342 May 13, 2009
    We have the same model. It is brand new and when you turn it on it firstly drains any remaining water, then lets in water several times before stopping and displaying 3 flashing red lights and a flashing blue light. The instructions simply describe it as a pump fill error but I can't find out how to fix it.
5 Suggested Answers
SOURCE: DWF 61 wont end programme
After a number of visits by an engineer, who just guessed at what it could be, and then ordered a part, changed the part on another visit, I insisted that a 'senior Engineer' visit, and be allowed sufficient time to make sure the problem had been solved. The senior engineer visited a week ago, and finally diagnosed what I had been saying for six months, " The water heater is not getting hot". The senior engineer visited yesterday and changed the 'HEATER UNIT DWF61' part number MS-1801925 (UK). Just before he changed the heater unit he found an electrical connection disconnected, so it may have been the cause of the heater unit not working, although he changed the unit anyway. All working fine now, so will renew my maintenance policy.
Posted on Aug 02, 2008
SOURCE: Leak from a De Dietrich
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Posted on Feb 09, 2009
MNfisherman
  • 11896 Answers
SOURCE: De Dietrich dishwasher model DVF300JU2
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Posted on Jul 12, 2010
rylee_smith
  • 8619 Answers
SOURCE: We have a Hotpoint DWF31 dishwasher which seems to
Hi
Thanks for using FixYa. Switch off the dishwasher from the power socket and mains and replace all the cables and switch it on after five minutes. You can also reset the breaker. If still the issue is not resolved then press and hold the "On/Off" button and release the button after ten seconds. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 20, 2010
The blue light and a red light under the glasses and plates signal is flashing and my dishwaser won't start.
does the door lock ?? if not try leaning against it when pressing the start button
Jan 21, 2015 | De Dietrich Dishwashers
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
De Dietrich dishwasher model DVF300JU2 Child opened door during wash cycle closed door but m/c did not restart,now all lights on! unable to clear/restart, tried to cancel programme by pressing 'Start' for...
Jul 12, 2010 | De Dietrich Dishwashers
Washer starts program but sound much noisier than
Suggest you check the water pressure out the pipe, then clean the inner sieve which is usually in the valve inlet. if all is clean and still little water enters, i would replace valve.Also, chech the pressure switch line an make sure it is not partially filled with water.
Sep 21, 2009 | De Dietrich 24 in. DVF120J Built-in...
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Oct 05, 2008 | De Dietrich Dishwashers
Built in De Dietrich dishwasher
I suggest you get all your staff to search tirelessly for an answer, ChrissyJ!
Oct 02, 2007 | De Dietrich 24 in. DVF120J Built-in...
De Dietrich 23 in. DVF110J Built-in Dishwasher Logo
281 people viewed this question
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
