Question about Canon PowerShot A400 Digital Camera
Have to reset date every time I turn on camera.
Every time I turn on the camera or switch to look at my saved pictures I have to reset the date and time. Not a huge problem just very annoying.
  • 2,016 Answers
You need to replace the date battery. It's a button-type battery (CR1220) which is in a holder near the regular batteries. After you pull the holder out, place the new battery into the holder with the negative side up, and slide it back into its slot. (Instructions are on page 120 of the manual if you have it.)
Posted on Jun 19, 2008
Dear Expert, I have a problem with my Samsung L100 camera with the time and date. Somehow when I have uploaded the pictures onto my computer it gives the date of the future for example: May 21st 2013....
The date of your pictures is from the date you took it, So, it must be that last year, May 2010, when took those pictures, your camera's date was not set to 2010. You must also know that when a camera's battery is totally drained and stocked for a long time, the date will be reset. So next time make sure that your date is always right on your camera. =)
But here is a good news. You can just change the dates now after downloading it to your computer. Go to the picture you want to change the date, right click on it and choose properties. Click on details, then "date taken" and change it to any date you want.
I hope this helped you.
May 21, 2011 | Samsung L100 Digital Camera
Date stamp function on Sony Cybershot S750 camera
This Camera doesn't have the feature to superimpose the date on the pictures. By using the supplied Picture Motion Browser Software, you can print or save the pictures with date.
Refer the following link to use the supplied Picture Motion Browser Software to print or save the pictures with date.
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
Feb 09, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
I have a sony cyber-shot dsc-w55 cammera, and my daughter turned the dial that changes the picture modes to many times and now it only records on every picture mode...any ideas how to reset it?
Based on the information you provided, it seems that the Camera is in Burst or Multi-Burst mode.
You may Initialize the Camera as follows:
Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Set the mode Dial on Camera. then, press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
Good Luck!!!!!!!!!!!
Nov 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera resets DATE and Time to Jan 2002 when
Some of these cameras cannot save the date, and has no internal battery to save the data. The best solution I have use is to buy another battery with these kinds of cameras and always have one charging, or take two batteries when you take pictures.
These older point and shoot cameras are nice, and slower than the newer ones, but will not save the data unless you keep the main battery in it, or replace the one to be charged with another battery within a very short time.
Sep 27, 2009 | Nikon Coolpix 4300 Digital Camera
Error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Jul 06, 2009 | Sony Cyber-shot W110 Digital Camera
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Polaroid digital camera a500
i cant get my vpc t-700 digital camera from saying no image i need to save my pictures thank you
Dec 28, 2007 | Sanyo Xacti VPC-T700 Digital Camera
Can't find time and dates for photos
What kind of camera are you using ? Most of the times, digital cameras record the date and time pictures are taken.
Jul 06, 2007 | JVC GR-AX710 VHS-C Analog Camcorder
Canon PowerShot A400 Digital Camera Logo
274 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
